4020 CHARGING
GlennM
04-22-2005 19:18:50
I have a 4020 Diesel (24V) that apparently is not charging. Any tips on determining whether it is the generator or regulator would be appreciated.
Thanks
buickanddeere
04-23-2005 06:49:12
 Re: 4020 CHARGING in reply to GlennM, 04-22-2005 19:18:50
Is the cut-out contact in the regulator corroded or burned away? Is there current flowing through the field windings? Is the fan belt new or not glazed? Is the generator pulley origional?
twopop
04-22-2005 20:34:26
#1.insure that the ground strap is correct on the left battery.
#2 does the idiot light on the dash work.if the light is burnt out or corroded it wont charge.
#3 disconnect wires at generator,with key on,a test light should show power at all 4 terminals,of the regulator.
#4 disassemble generator and remove armature.check the brushes.use a vom to check for continuity of the field coils.continuity should be from inside top term. to bottom term.of generator housing.if all this checks good,it should charge
Bob
04-22-2005 22:31:38
 Re: 4020 CHARGING in reply to twopop, 04-22-2005 20:34:26
I hate to disagree, but a generator 24 Volt system will function JUST FINE with a failed "idiot light". However, in an alternator system the "idiot light" is part of the "excite circuit" that gets the alternator charging at each startup.
If you have a generator, the "idiot light" is not your problem.
Chip
04-22-2005 19:31:21
Make sure the small wire is connected from the frame to the LEFT battery and not rusted off.
