One possibility might be that it is missing under load but then firing at the next TDC which would be the end of the exhaust stroke and the beginning of the intake stroke as standard mags and distributors fire on each and every crank revolution. The mixture at this time would not be under much pressure but still be combustible and would go both ways - out the exhaust AND backfire into the carb. Compression pressure may be causing the spark to not occur if you had a maginal spark making the above senario even more likely. And yes, mags can and do do this. Mine would be lugging along and then completely miss a shot at random creating a stumble, if this happened again before she had a chance to recover from the first stumble I had to de-clutch or she would up and die. Same with my B. Then my mag broke and I bought a distributor since it was the cheaper alternative and I was then able to use a Pertronix 3 ohm coil with the standard points. The stumble disappeared altogether. And it's this fact alone that allows me to point to the mag as the cause for it. It was random, some days not so bad, but on others it was so horrible I had to drive with my hand on the clutch ready to pop it out at any and all moments. Yet when I would check the mag, the points looked good and were set correctly, the timing was right on, and even the spark was hot, good and blue. It was the intermittent bad spark that I could NOT check that was making the stumble happen here and so I too was stumped. Maybe you could borrow a different mag or distributor and see if the problem changes or goes away? It could be a sticking intake valve problem or a mixture problem as well - but my bet is a different mag will make it drive like a different tractor and then you'll know what it was.
