212 engine mount and voltage regulator questions
steve wade
04-22-2005 17:56:17
I just bought a 1984 JD 212 (in great shape!) off of a guy for 100 dollars. He told me it needed a new alternator because the battery wasn't charging. However, I brought it in to a repair shop and they told me it was the voltage regulator because it wouldn't 'hold a charge'. I'm more apt to beleive the repair shop (they are a JD dealer)...but I'm able to crank the engine it just won't fire. Which tells me the battery is at least getting some juice...any ideas...because it doesn't seem that that would be a by product of the voltage regulator.
They also told me that the engine was loose in it's mounts and that they wanted to charge me a total of 650 dollars to replace the voltage regulator and take the engine out and re-bore some holes to mount it to the frame (I couldn't afford that!) Any ideas on more cost effective ways to have the engine mounted more securely? I've never really worked on one before but I'm willing to jump in and give just about anything a try. Thanks.
Bob
04-22-2005 22:41:36
 Re: 212 engine mount and voltage regulator questio in reply to steve wade, 04-22-2005 17:56:17
If the tractor is not starting, the voltage regulator has NOTHING to do with that.
If a 212 is not "holding a charge", I take that to mean the battery goes dead while it's sitting shut off. That ain't the regulator, either, because the key switch disconnects the charging system from the battery when the key is shut off.
You can replace the motor mounts yourself, it's really not that big of a deal.
The engine has a simple 12 Volt battery ignition system. For ignition troubleshooting hints, look at the .pdf manual HERE:
(Battery ignition section starts on page 73 (section 8.3)).
