J.D. 316 w/Onan engine
Oldman1
04-22-2005 10:16:28
I have a John Deere 316 lawn tractor that will idle but if you give it gas it will die. Tinkering with carbeurator will let it crank and run for one grass cutting. You must have choke all the way out for it to run. I have replace fuel pump, needle and seat in carb. The tractor acts the same whether the fuel filter bowl is full or almost empty.
Henry J
04-22-2005 17:28:48
 Re: J.D. 316 w/Onan engine in reply to Oldman1, 04-22-2005 10:16:28
Oldman
I think you have a classic case of gunge in the main jet mechanism.
I have not qworked on your particular engine but here is the first thing I attempt to do on a motor with that ailement. If it has a screw on the carb for the main jet, gently screw this in until it makes contact with the seat while counting the number and fraction of turns. Now screw the jet all the way out, take your favorite can of carb cleaner (but not the environementally safwe kind) , put on your safety glasses and a tube in the nozzle of the car cleaner can. Now put the end of the tube in the hole where the main jet adjustment came out of and blast the haities out of it. Let it set a few minutes, give it another blast and put the jet needle back in at the same setting as it cam out.
This may just do it.
I have done this on many of the old non epa type carbs.
oops, forgot to say, keep a rag under the carb to catch the cleaner so it won't remove or damage paint.
good luck
Oldman1
09-19-2005 10:31:54
 Re: J.D. 316 w/Onan engine in reply to Henry J, 04-22-2005 17:28:48
It's been awhile since I've been to this website.
The solution to my problem was a leaky intake manifold. Replaced it with a $20 used one.
Thanks.
Bob
04-22-2005 14:24:32
Those Onan carburetors are notorious for having plugged jets in the main body.
Take off the top, using the "snorkle tube" on the can, flush spray carburetor cleaner through all the ports and passages in both halves of the carburetor, followed by compressed air, and then repeat.
Take care not to loose the float hinge pin or the inlet valve needle when you're using the air!
