4020 transmission sump screen and hydro pump filte
Jason Z in MO
04-22-2005 08:27:05
I have an early 4020 syncro-range tractor. A couple years ago I pulled the final drives to replace the brakes. At the same time I replaced the load control shaft seals and bushings. The brakes were a mess and had lots of metal down in the bottom of the transmission. I cleaned everything out with a magnet and flushed it will diesel fuel.
Lately, I have been hearing about a sump screen. No where in the service book can I find anything about it. However, I did find it in the parts book. Since I didn't know it was there, it didn't get cleaned when I did the work but I am sure it needs it!
It looks like there is a plug on the side of the transmission. There is about a 1 1/2" plug past the trans oil filter toward the rear axle. Is that it? I also assume the oil will need to be drained.
Also plan to clean the hydro pump filter screen. If I can get access to it.
Thanks!
Bob
04-22-2005 09:17:50
 Re: 4020 transmission sump screen and hydro pump f in reply to Jason Z in MO, 04-22-2005 08:27:05
Sounds like you've found the right plug. And, yes, it is at the bottom, so the oil's gotta be drained.
Ducknose Bob
04-22-2005 10:44:43
 Re: 4020 transmission sump screen and hydro pump f in reply to Bob, 04-22-2005 09:17:50
While you have it out, you might want to consider putting a cow magnet inside of it. JD does offer a kit to accomplish this for @ $85.
