GVJ, Whats usually involved when I changed one are an assortment of bad words lol. The manifolds not so much the problem, its getting those rusted frozen studs out of the head without twisting them off, plus getting the manifold to release its rusted grip on the studs so it can be raised off the head. I have seen them cracked, but its more often a case of rusting through and/or beign all burned out and not smooth n flush where they mate with the head. If you manage to get it off in one piece, I always have the machime shop plane them down smooth on the bottom where they mate to the head. Heres a few general things I do but you may luck out and the nuts n studs all come out easy, if youre a praying man it cant hurt before you begin. 1) Start with a good soaking of everything over a period with PB Blaster or Kroil or other penetrants. After that I apply heat to the nuts and I drive a 6 point socket tight on them which may be metric or an undersize to get a good grip. Then I use a hammer on the wrenches end to shock/hammer/vibrate them loose NEVER A HARD DEAD PULL and if they ever start to budge, slowlyyyyy yyy milk them in n out in n out till they are off. If they break off so be it, they still gotta come off regardless. 2) Once the nuts are off, I tap/shock/hammer all around the manifold to see if she will free up to raise off the studs AFTER soaking with PB Blaster or Kroil etc to try n get it to flow down around the studs. 3) If you can get thin wedges/drivers etc under the manifiold between it and the head try n see if you can get it to raise evenly around it. 4) If worse comes to worse you might be able to get it raised some enough to get a hacksaw or sawsall etc under it to cut the studs off. 5) If you get the manifold off and theres any studs sticking out, I heat them but let them cool so theyre not soft, then slowlyyyyy y n carefuly use a stud remover or a small pipe wrench etc to get a bite and tap the wrench end with a hammer (NEVER a hard dead pull) back n forth back n forth till she might come out. 6) If the stud breaks off and theres a lot of it left, I weld a nut to the stud then use a wrench as above slowly hammer/shocking it back n forth. 7) If it breaks off so close theres no bite left, I FIRST weld a flat washer to the stud then a nut to the washer n try as above. 8) If shes still there, I file/grind it nice n smooth so I can dot punch the exact center and start with small followed by larger hardened drill bits till I drill it out then re tap. Some people end up with left hand drill bits which might extract it better. CAUTION dont drill too deep on some heads you might get into the pushrod tubes. 9) After the manifold is planed smooth have the head surface also clean n smooth as you can get it and I use plenty of anti sieze in the manifold holes and stud and I use brass or stainless top nuts n washers and high temp silicone on the gasket n head n manifold then torque her down and after a few good waRM UPS RE TOUQUE HER. Im sure other gents have different n better methods, this is just what has worked for me. John T Nordhoff in Indiana
