2020 Problem
tdangus
04-22-2005 03:21:33
My 2020 gas tractor w/148 loader will stop moving in forward or reverse direction with heavy usage which is effected more when I use the PTO. It doesn"t smell like the clutch is heating up. Could a rebuild on the hydro pump possibly fix the problem? After the tractor is left idle for about 30 minutes everything works fine.
Any ideas?
Tx Jim
04-22-2005 03:48:09
 Re: 2020 Problem in reply to tdangus, 04-22-2005 03:21:33
tdangus,more info is needed to dianose.Does tractor have hyd.hi-lo or directional reverser?What type pto does it have.I think that a rebuild of hyd.pump will not solve problem,if problem is hyd. related it's probably an internal leak in a hyd component.Tx Jim
