J.D. 316 Kohler
mitchell hastin
04-21-2005 17:52:31
I recently had my kohler motor rebuilt and just installed it last week. started to mow a little and noticed the governor wasn't letting the motor get enough rev's with the deck on. so i loosened the clamping bolt on the throttle linkage that's attached to the governor shaft, and marked the shaft and the linkage before i moved it from its original position. after i adjusted it not more than a 1/16th of an inch the governor stopped working entirely. i took the throttle linkage off the shaft started the motor and gave it a little throttle and nothing no rotation. what's up? and if something�s wrong with the governor itself do i have to take the oil pan or the back cover off the engine.
Bob
04-21-2005 22:02:55
 Re: J.D. 316 Kohler in reply to mitchell hastings, 04-21-2005 17:52:31
If the governor hasn't fallen apart inside the engine (or broken), an adjustment is all you need.
(ENGINE "OFF" for this:)
Remove the linkage from the carburetor lever.
Adjust the position of the governor lever in relation to the governor shaft so that when the carburetor throttle shaft is held at the wide-open position, and the governor is in the wide-open position, the linkage has traveled just beyond the point where it will drop back into place onto the carburetor lever. Tighten the clamp on the governor arm to lock the governor shaft and arm in this position. Install the linkage back onto the carburetor throttle lever.
That little extra travel of the governor beyond the point at which the carburetor throttle is wide-open ensures that the governor will be able to fully open the throttle.
This adjustment puts the governor and carburetor throttle shaft back into the proper "sync".
