1977 model 300 garden tractor hydrostatic drive
marlin
04-21-2005 17:14:32
Help! I need info. Tractor is leaking where drive shaft enters the hydroststic drive. How difficult is it to change the seal? Need any inst. available, or where to find details.
Bob
04-21-2005 21:53:34
 Re: 1977 model 300 garden tractor hydrostatic dri in reply to marlin, 04-21-2005 17:14:32
When I have done this, I remove the casting that the seal is pressed into. That casting contains a geroter charge pump, and is held on with two bolts.
Remove the driveshaft, clean the area around the pump. Clean and de-burr the shaft. Mark the casting as to which side is up. Remove the pump casting assembly, and replace the seal. The rotor in the gerotor pump is pinned to the shaft with a small hardened pin, and the point of my build-up to all this is that often, the pin wears and breaks. (If it breaks, it tears up the $$$$ pump.) While you have it apart to replace the seal, check the drive pin, and replace it if needed. Also, there is an "O" ring between the pump body and the main body of the hydrostat.
Lube the parts up with the oil used in the hydro before re-assembly.
Seal..... . #M45400 $12.25
"O" ring... #M45375 $2.30
Pin..... ... #M45395 $0.80
mph
04-21-2005 18:05:47
usually drive line seals are easy to replace you must remove the drive shaft and the yoke or the part that joins the drive shaft to the transmission and also is what the seal is rubbing against to keep the oil from coming out. After removing those two components it's just a matter of digging out of the old seal. This can be frustrating and time consuming but be patient and don't get in a rush and risk scratching a metal surface with your instrument of choice. Some people use dental picks, screw drivers, cold chisels, just about anything that will get to and or dig out the seal. After the seals out make sure to lube up the new seal where it mates to the drive shaft coupler, and drive it in. I usually use a brass hammer, or drift. It might be tricky to get it started at first without it getting crooked try using a large socket that's just the same size as the seals metal ring. Hope this helps
