3010D What chassis designation (picture)
F-I-T
04-21-2005 16:24:11
third party image
Is this a "Utility"? Being from Ohio, I never saw one like this. It's not a Standard, is it?
This is in the photo ads. I wish it were closer to Tallahassee. It would be nice to fit under my tree limbs!
Frank
msb
04-21-2005 19:26:21
 Re: 3010D What chassis designation (picture) in reply to F-I-T, 04-21-2005 16:24:11
Row Crop Utility.Very similar to the 3010 Industrial except the final drives, rear wheels,hood, front cowling and front axle were much heavier built on the Industrial .I still have an old 3010 Industrial, hoe and loader.
Tom (Ks)
04-21-2005 18:28:42
They are a pain in the #*@ to work on.
Timberoak2119
04-21-2005 18:07:21
Looks like a utility to me as you straddle the transmission. I believe on the standard the floor board is flat like a row crop. Front axle on the utility could be turned around to make a short wheel base long or or long to short, needed to buy two steering lines to reverse steering motor or unit would steer backwards.
F-I-T
04-21-2005 18:11:33
 Re: 3010D What chassis designation (picture) in reply to Timberoak2119, 04-21-2005 18:07:21
Wow! Like that and with power brakes and power steering and a loader it would have been pretty maneuverable I bet.
G/MAN
04-21-2005 16:29:47
If the front-axle is adjustable (it looks like it MIGHT be?), I'd say it's a row-crop utility. The rear fenders look about like what's show for the RU in the parts book. If it's not adjustable, then it would have to be a standard. One things for sure, it'll be loads of fun pulling the back wheels with the hubs installed outside the wheels and the wedge screws pointing in. That's how it looks like it's put together to me, at least.
F-I-T
04-21-2005 16:48:13
 Re: 3010D What chassis designation (picture) in reply to G/MAN, 04-21-2005 16:29:47
"One things for sure, it'll be loads of fun pulling the back wheels with the hubs installed outside the wheels and the wedge screws pointing in"
That thought occurred to me as well. Sadly, been there, done that.
Thanks! I think one of those fixed up would be kind of handy. I was thinking that the short steering column might signal a utility dsignation.
Frank
sodly
07-23-2006 12:23:27
 Re: 3010D What chassis designation (picture) in reply to F-I-T, 04-21-2005 16:48:13
Could you please contact me regarding the differences between the standard row crop 3020 and the utility row crop 3020? I have some questions and it sounds like you have researched this to some extent. Thanks!
Bill-NNY
04-21-2005 17:57:21
Frank,
The 3010 is a utility. The dropped footrests and the throttle handle pointed up are two of several differences between a rowcrop/standard and a utility. The standard would have a flat platform, same as the rowcrop. I looked into a 3020 utility near here and looked into parts interchange with a rowcrop 3020. Hope this helps,
Bill
F-I-T
04-21-2005 18:01:32
 Re: 3010D What chassis designation (picture) in reply to Bill-NNY, 04-21-2005 17:57:21
Cool! Thanks Bill!
Never got to see one up close like that.
Frank
