720 poping out gear
Rousseau
04-21-2005 16:02:08
I am having a problem with my 720 comming out of gear under a hard pull.I have taken this trans a part and can't see what is goin on.How much presure should it take to move the shifting fork,is there a lock?The gear I am having problems with is 2nd and 5th.When it pops out it makes a pop sound.
Thanks for any info
Rousseau
billonthefarm
04-21-2005 16:37:38
 Re: 720 poping out gear in reply to Rousseau, 04-21-2005 16:02:08
It seems to me it really doesnt take much of a detent to keep the fork in place if everything is ok. I had to do some work on a 70D and it had far better detents than my 70 gas but because of some worn bearings in the trans letting things not run true it was just impossible to keep it in gear under a heavy load. No bearings had failed but several needed replaced. It took me two tries to get it right. The first time I took it apart and looked the second time I spent some money and replaced every bearing that wasnt perfect. Good luck.
F-I-T
04-21-2005 17:31:40
 Re: 720 poping out gear in reply to billonthefarm, 04-21-2005 16:37:38
Sometimes it's not just the bearings, though they are often a contributing factor. I have a VAC Case that jumps out of a gear now and then under a hard pull. It has all new bearings, new detents, and springs. But....there is some wear on the third gear that I think has changed the geometry to the point that that the gear crawls up the tooth until pops out. A detent can't hol against that pressure.
Short of reshaping or rehobbing that gear face or finding a NOS gear, I may have to live with it.
You might get by with new springs and pawls.
Frank
