530 JD-engine shut down-low oil pressure and won't
Chris Stuva
04-21-2005 14:09:35
After using my 530 gas last week, the engine shut down. No noises or missing prior to it shutting off. I tried to restart and the oil pressure does increase, but not past the stop on the oil gauge. No knocking or odd sounds in the engine when cranking over. I have heard the gas shut off (Low oil shutdown) in the sediment bowl assembly can cause this. I didn"t see any oil in the bowl or gastank.
Any Suggestions where I should start?
ChuckW
04-21-2005 19:19:44
 Re: 530 JD-engine shut down-low oil pressure and w in reply to Chris Stuva, 04-21-2005 14:09:35
I'd pull the plugs out then crank at high speed and see if the pressure comes up to normal. If not you have an issue with a filter or pump. I would then change filter and flush out the engine. Use new 10/40 oil or straight 30 hd and see what you get.
MSM
04-21-2005 15:16:40
If the engine is not building oil pressure,it won't let gas into the carb through the shut off in the sediment bowl.You will have to address the loss of oil pressure; no oil,clogged or collapsed oil filter,broken oil pump drive coupler,failed oil pump,broken oil feed line in the engine,clogged line feeding the oil guage/fuel shutoff.
F-I-T
04-21-2005 16:07:28
 Re: 530 JD-engine shut down-low oil pressure and w in reply to MSM, 04-21-2005 15:16:40
MSM is right on here. I haven't fiddled with one of those oil-pressure operated valves for a long time, but isn't there a brass nut on the sediment bowl that you can hold down or lift up to manually fill the carburetor? If you can open the carburetor bowl drain, and by operating the sediment bowl maunally, get fuel to flow, you might be able to get the engine to fire and run for at least on carb's worth. Then you'll know what you have to repair.
Wish I could offer more, but I bet that's where your problem lies. You could always give it one short snort of ether and see if it fires all right....that always proves it's a lack of fuel and not spark.
Frank
