4020 Vent Tube
O'Neil
04-21-2005 13:39:12
What is wrong when the crankcase vent tube puts out a lot of steam/smoke on a 4020 ? mine seems excessive. thanks for your help
Chip
04-22-2005 19:48:59
 Re: 4020 Vent Tube in reply to O'Neil, 04-21-2005 13:39:12
Mine started blowing smoke out the tube also, spun a rod bearing. Oil got extremely hot. Lots of smoke out the tube that smelled bad.Hooked up an oil pressure guage and the neddle on the guage would quiver or surge every time the bad rod rotated around.
Glen Anderson
04-22-2005 07:12:04
If your 4020 is equipped with a ventilator pump you will notice considerably more blowby as opposed to an engine without a ventilator pump. If upon inspection you don't notice fuel dilution in the engine oil or coolant leaking into the crankcase, it is likely a sign of a pending engine overhaul, however if the hp. that is presently available is satisfactory, keep driving it!
3010 Ken
04-22-2005 04:24:47
Mr.Oneil; In all probability what you have is excessive crankcase pressure caused by worn internal parts i.e. rings,liners,pistons,etc.Your engine may be like mine in my 3010,just a lot of hours and time for an overhaul.Good luck!Kenny
msb
04-21-2005 19:33:52
Have you kept a close eye on the oil level.You could be getting some dilution in the oil.If not then it is probably due to engine wear.If you want to cut down the blowby then plug off the ventilator pump if it is a 1968 and back model.Remove the line from the ventilator pump to the intake manifold and find a rivet that will fit in the fitting on top of the vent pump or you can use a ball bearing that fits on top of the fitting and then replace the line.
G/MAN
04-21-2005 16:35:45
I think a guy can actually do a crankcase-pressure test with a manometer. Deere has specs for how much blowby is "too much". It also seems like some oils are prone to forming vapor easier, and produce more "steam". I generally put more stock in how the engine performs under load, its horsepower and oil consumption than I do in how much blowby it produces. Does it leave a puddle under the tube when running in one place?
O'Neil
04-21-2005 17:40:54
 Re: 4020 Vent Tube in reply to G/MAN, 04-21-2005 16:35:45
Yes G/Man it does puddle when sitting in one place , about one drop every 3 seconds or so, What does that mean?? Thanks
G/MAN
04-22-2005 07:35:24
 Re: 4020 Vent Tube in reply to O'Neil, 04-21-2005 17:40:54
I'd say she's getting tired. That's pretty fast to be dripping oil out, although the 4020 valve covers don't have as good of a baffle as the later models, to keep the oil in and let the vapors escape. Pulling the nozzles and performing a compression check would be my next step.
O'Neil
04-22-2005 09:34:48
 Re: 4020 Vent Tube in reply to G/MAN, 04-22-2005 07:35:24
The puddle is water not oil, does that change anything? Thanks O'Neil
Jason Z in MO
04-22-2005 13:37:02
 Re: 4020 Vent Tube in reply to O'Neil, 04-22-2005 09:34:48
Not an expert but can offer a couple of ideas.
First of all you need to run her long enough to get it up to proper temperature and evaporate condensation. If the engine doesn't reach proper operating temperature then it may have a condensation problem. Especially during the winter months (depending on your climate). If you are running her long enough and under some load then you might have a thermostat or two that are stuck open.
The only other source of water that I know of is the cooling system. Are you loosing coolant? You can remove the cap when the system is cool and not pressurized. Start the engine and look down into the radiator for bubbles. If you are loosing coolent or find bubbles then there may be an internal problem like head gasket, sleeves, liner seals, etc. This list was covered in the previous response. If your lucky, the other place you could mix water in the oil is the oil cooler. Its external to the engine. It's the vertical tube on the right hand side of the engine. Just to the right of the dip stick.
Another sign of coolent in the oil is milky and or foamy oil.
The other guys have a lot more experience they probably have better advise. I will only tell you what I know for sure.
MSM
04-21-2005 15:02:11
Water in the crankcase,worn cylinders/pistons,cracked piston,broken rings,pinholed liner,cracked head,blown headgasket.....
