2020 pto clutch
Gary in TX
04-21-2005 11:33:26
Hey guys,
I just got a 2020 diesel and everything seems to run fine on it with the exception of the pto clutch. It will engage fine with nothing hooked too it, however when the mower is on it it grinds when you try to engage it. You can engage it, crank the motor adn it mows fine. Been told the pto clutch disk is likely stuck to the pressure plate? Any tips on freeing it up without splitting the tractor? Other than this I'm pretty pleased with it. Looks good out there wiht the 4230 and the 4430.. Tractor has apparently sat for most of the past 3 years according to the scratched date on the oil filter with the hours. Shows only about 25 or so hours in the past 3 years. Thanks in advance!
04-21-2005 16:28:02
 Re: 2020 pto clutch in reply to Gary in TX, 04-21-2005 11:33:26
I`m assuming its equiped with live PTO, not live independent. That means a two stage clutch to engage the pto. Make sure that the clutch pedal is correctly adjusted and you push it all the way down to disengage the pto clutch. If that fails maybe its possible to free the plate thru the throwout bearing lube hole. Thats the 3 inch round cover on the left side of the clutch housing. Good luck and maybe you can avoid splitting.
