Adding front weight to B
Greg A
04-21-2005 05:58:26
I would like to add some temporary weights on the front of my B to counter the weight of 3-point implements (brush mower, corn planter). Does anyone have any suggestions of what to use for weights and how and where to attach the weights
JDVan
04-21-2005 23:43:27
 Re: Adding front weight to B in reply to Greg A, 04-21-2005 05:58:26
The difficulties you are having is why JD did not reccomend using the 800 Series Hitch on the pressed steel frame on the A"s and B"s. However, JD did recommend use of the 800 series hitches on the G. It never went to the pressed steel frame and therefore was heavier in the front. JD did sell front wheel weights for the A & B but originals are a bit difficult to find.
You can add front weight using the methods others have suggested in this thread.
ChuckW
04-21-2005 19:16:25
A front rack weight holder would be very simple to build. I've always thought this was a design flaws of the stamped frame design.
Jason Z in MO
04-21-2005 10:55:43
My grandpa solved the problem in a similar manner but built a wooden box instead of using iron. Took a couple of rough sawn oak 2x6"s bolted them to both sides of the frame extending a couple of feet in front of the tractor. Then built a wooden box on top of that. I have seen it loaded with bricks, scraps of iron, etc. It also doubles for a good hauler for rocks picked up in the field.
CMB
04-21-2005 09:44:42
Many years ago I had a "G" with an 801 3pt hitch. I mounted a 15 1/2ft "C10" field cultivator on it. When I lifted with the "Power-Trol there was some question as to whitch end would leave the ground first! Ended up bolting a pair of 4" channel iron to the frame,& welded a crossmember with holes that were attached to the front pedestal studs. Welded another angle at the front,& just stacked enough wheel weights on it to hold the front down(as I remember it needed 3 or 4). That "G" was equipped with aluminum pistons & a gas manifold,& would go anywhere easily in 3rd gear set up that way. Over the next few years, I prepaired literally thousands of acres for planting with that outfit.
Ben.So.Tex
04-21-2005 07:12:10
Water will work in the tires,,,, If it freezes in your part of the country you may want to build a wieght rack..Good luck Ben
Mike M
04-21-2005 06:17:00
I made a simple weight bracket for the front of my late B. I just ran angle iron up each side of frame rails bolted it on then welded a cross bar and tied into the front pedestal bolt holes have a cross bar farther out to hang the small suitcase weights from our compact tractor on.
