52 G fan shaft
JIm G
02-21-2004 14:49:36
having major trouble. i have fan shaft off gov. tried heat,pullers to remove gear it moved a little then gear started shaving the shaft. i have blade and pulley off thinking i could remove shaft from other direction. should the shaft slide out the gear side with all that removed. i can't seem to find anything else holding shaft in place. do i need to romove felt Oring retainer first. could use any help thanks
Gman
02-21-2004 18:38:10
 Re: 52 G fan shaft in reply to JIm G, 02-21-2004 14:49:36
Jim if you are trying to replace gear there is a snap ring holding it in place plus keyed on shaft. To diassemble fan shaft get plent of pentrating fluid(Blaster and some patience). Soak fan shaft keepers several days and apply down pressure on on pot metal slip clutch(be careful they break aweful easy keep this up till you can remove the two keepers after you get the keepers out the clutch is still a pain to get off,remember a little patience and penatrating fluid it will come off. You need to take shaft clear down to inspect bearings,after you get clutch assembly and felt washers and bearing out of fan end the shaft will slide out the gov. housing end that bearing needs to be change if its rough of course the gear will have to be removed don't forget the snap ring,then you need to locate the bearings they are a little difficult to locate because they are a three pirce arrangement JD 7656R,JD 7657 R.JD 7655R and this bearing fits both ends of shaft hope this helps Garland
Clooney
02-21-2004 15:22:06
Jim, that shaft should slide out the rear with the gear still on it..
~Sometimes the front spacer or bearing sticks to the shaft due to corrosion or galling.. Try pulling all you can off the front [I believe there is a spacer behind that front pulley]
~Put a piece of hardwood or aluminum on the concrete floor & try slamming the fan shaft down on the front of the shaft. If it comes loose good, if it doesn't you are in for a fight. There is a big spring in there that absorbs the shocks so that makes dislodging that front bearing difficult if it's galled on the shaft.. Try not to damage the front retainer or spacers as I'm not sure what's still available from Deere. Sometimes putting the front of the shaft on the floor then pushing down as hard as possible will push the gear out the rear a little then a wedging something like pliers or adjustable wrench between the back of the gear & housing will help keep pressure on the front bearing & compress the spring so the shocking will dislodge the front bearing..
~You should be able to get that rear gear off with heat [maybe you didn't use enough] & a gear puller.. OR, better yet put a gear separator under the rear gear then put the whole thing in an arbor press..
[email protected]
Jim G
02-21-2004 16:38:15
 Re: Re: 52 G fan shaft in reply to Clooney , 02-21-2004 15:22:06
thanks clooney,I'll try what you mentioned. we did put the heat to the gear, maybe too much, shaft ended up red. i did try a block of wood on the blade side with a sledge,and didn't budge spring absorbed it all. all this for a $2 O ring. thinking of taking it to a machine shop. if you think of anything else I'd apprieciate it. Jim
