JD 2010
Jonak
04-20-2005 20:31:25
The three point hitch on my 2010 will lift it's own arms, but nothing more. Front loader on the remotes, works good. Any ideas what could be wrong with the three point hitch???
billde
04-21-2005 04:23:15
 Re: JD 2010 in reply to Jonak, 04-20-2005 20:31:25
Remove the seat and rockshaft cover plate, there is a pressure test port on the right side, slightly forward inside the housing. You should have about 1500 psi. It is an absolute must to have access to a service manual to make the adjustments you may need to make. let us know your progress. Hope you don't have to remove the rockshaft housing and do a rebuild.
