Block Cracked
Mattg
04-20-2005 13:06:34
Hello All,
I have an John Deere 60. The orginal block I had cracked, so I purchased another used one from an Individual. He told me that he had it pressure tested before he sent it to me. This was last August. I finally got it into the machine shop after the winter is over. They were cleaning the block up, and getting ready to hone the cylinders and found a crack in the wall. They said that they could clean the back of the crack and JB weld it. I guess the crack is near the end of the block where the cylinders dont really go.
My questions. 1. This is going to be a work tractor that is used quite a bit, will this hold?
2. Is it possible the first guy did pressure test it and the crack did not show but was weakened?
Thanks
Matt
Lee B
04-24-2005 02:28:59
 Re: Block Cracked in reply to Mattg, 04-20-2005 13:06:34
My neighbor said it best I'm thinking, "They say they can fix those, but I don't think they really can". Three oven heats on my cracked block resulted in new cracks showing up each time. After $300 and three months in their shop, I quit them and wound up using 6 large bottles of Bar's Leak. I can't recommend going after those cracks with any hopes at all.
If it's a small crack, JB weld can't hurt but rely on massive amounts of Bar's leak for main protection. My guy swears that the cracks happened overnight while the block sat on the bench, so your guy might be telling the straight up truth. My guy couldn't pressure test it but he did fill the water jacket with solvent and looked for seepage on the cylinder side - it passed his best test, but in the field, looked like a stanley steamer anyway.
Mattg
04-21-2005 08:38:54
 The Crack is located in reply to Mattg, 04-20-2005 13:06:34
About 1 inch from the end of the cylinder wall. It is opposite of the spark plug hole. It is on the inside of the cylinder wall. It is towards the end of the cylinder, where the rings nor piston slide past. The machine shop seems to think it will be ok as the fix will be on the water jacket side and not really in the cylinder. Right now, I am hoping this fix will hold until the end of working this summer, than maybe I will get the blocked sleeved or look for another one.
Thanks for all the advice.
Matt
Mike M
04-21-2005 13:07:24
 Re: The Crack is located in reply to Mattg, 04-21-2005 08:38:54
That will be near impossible to fix so it will hold as that area takes all the stress from the studs. Save yourself lots of trouble and find another block that is good.
JS-OH
04-21-2005 08:58:41
Why not bore/dry sleeve it now while you have it out?
Glen Anderson
04-21-2005 08:06:29
Matt, as the other fellows have said, it depends where the crack is whether it's repairable or not. Methods of repair can range from cold or hot welding procedures, stitching, and even JB weld. I've seen all methods used with considerable success on the right application(type of crack/location). Certainly it is preferable to replace a cracked block with one that isn't, however cost and supply will influence a persons desicion to attemp a repair. Despite what some people might say, repairing a crack in cast iron is not necessarily a foregone conclusion.
toot
04-21-2005 05:58:48
Find out exactly where the crack is, and you will get some better opinions. I will say if the the crack is in the cylinder WALL jb weld is good stuff, BUT not that good.
Mike M
04-20-2005 19:01:09
Depends on where that crack is. Those blocks like to crack near the top stud holes inside the cylinder wall which will only worsen when you tighten up the head.BEEN THERE DONE THAT! If you have a freeze crack on the outside water jacket I have had some fixed by a good welder if you don't mind the looks.
RustyAL
04-20-2005 17:10:36
I would not sink time and money into a cracked block. You could use it cracked and have good luck or bad. I work for a major aircraft engine remanufacturer and the blocks get inspected for cracks no less than 4 times. It is common to find a crack on the final inspection. The cracks seem to open up as the block is processed. They are most noticable after being heated for weld.
