Deere Warranty
Luis Rodriguez
04-20-2005 11:46:28
I have a L110 and I have had no problem with it. However I wanted a good quality trimmer and I went with the S1400 John Deere. I started to have problems with it from day 1. I took it to the service shop where it was "repaired". After a few minutes of use, it would break again. I had to take it four times for the same reason and it was never repaired properly. Now they say that the unit is out of warranty and that they cannot do anything for me. I tried everything but no results.
Bottomline, I will not ever get any other John Deere product as they seem to have a unilateral warranty policy.
McC
04-21-2005 15:38:02
 Re: Deere Warranty in reply to Luis Rodriguez, 04-20-2005 11:46:28
Unfortunately that unit was made by Homelite back when Deere owned Homelite. Deere sold Homelite 2 or 3 years ago. I think they had a 1 year warranty, so it sounds like the unit you purchased was probably old stock. The warranty should begin when you bought it. Talk to the service manager first...then talk to the Deere territory manager for your area. You should get some response. Hope this helps.
Luis Rodriguez
04-21-2005 17:18:30
 Re: Deere Warranty in reply to McC, 04-21-2005 15:38:02
Every party involved was notified in writing about the issue, JD Main Office, Homelite, seller of the unit and JD Service Dept. Guess what... I got a call today from Home Depot telling me to go to the store where they would refund the total cost of the unit, no questions asked. How about that! They did not have to do it as they are not responsible for servicing the unit, but they went a step ahead because they care for their customers (their business, bottomline). I am telling you, they are keeping a customer and of course they will be getting my business.
It is now a closed issue for me. No more JD.
Thanks to all who replied with suggestions.
Luis Rodriguez
04-21-2005 10:03:49
Thanks JDAOS, Mitchp, Hax, Mike and DP for your replies. In fact, the dealer wanted to get me a new unit to honor the warranty when the unit was still covered but John Deere Main Office did not allow them to do it and made them "repair" my unit instead. They did it even when they knew that the repair was not going to hold. It was back in October, so aI used it only once and put it away for the winter. When I used it again a few weeks ago, it broke down again, as we all expected. When I took the unit back to the dealer, they said it was out of warranty. I wrote to JD, Homelite (manufacturer of this poorly designed unit) and the dealer. JD shut the door and said "Sorry for you, nothing can be done", get yourself a new unit.
What put me in shock because I had a different concept of JD. I have two options, A) get a new unit and B) parade in front of the JD dealer with a big sign complaining about their warranty". One thing is for sure, I will never buy any JD product, neither will my friends and neighbours if I can avoid it.
Mike M
04-21-2005 13:21:54
 Re: Deere Warranty in reply to Luis Rodriguez, 04-21-2005 10:03:49
Before you go and throw it through their front window or something,go back and talk to the service manager.If they indeed fixed it even after stateing it wouldn't hold up and wanted to give you another one. Have them call the area service rep. on the phone and explain it to them and let you talk to them too. Unfortunate but true you have to sometimes revert to being a real bi*ch to get things right. The squeaky wheel does get the grease.The ungreased wheel gets the shaft.
JDAOS
04-21-2005 09:27:26
I heard somewhere that the only product Deere won`t stand behind are their manure spreaders.
MITCHP
04-21-2005 07:23:42
I THINK HOMELITE MAKES DEERES OUTDOOR PRODUCTS. I KNOW THEIR CHAINSAWS ARE MADE BY HOMELITE
G/MAN
04-21-2005 16:37:11
 Re: Deere Warranty in reply to MITCHP, 04-21-2005 07:23:42
No, they're not, and haven't been for several years.
Hax
04-20-2005 13:08:43
Like others have said go above the dealers head, and make him look bad, and maybe you will get results. However for a quality trimmer purchase a Stehl, {unsure of the spelling, since I'm not holding my trimmer, or chain saw in my hand}. I've owned one for 11 years, and all I've ever had to do is add gas, and trimmer line. Same goes for everyone in my family. Three siblings families, and parents. My father still uses a chain saw by this company that he purchased back in the early 70's. I'm certain Deere didn't make your trimmer, but they should atleast help you out more, but again as said before, this is more a dealer issue than the mother company. Good Luck Greg H.
Mike M
04-20-2005 12:48:16
JD has that 30 day promise. Problems from day one I'd of took it back to them within 30 days and gave it back to them. Try getting ahold of someone from JD's headquarters and show them all the proof of the attempts to fix it and see if they will help. You must bypass the dealer and go to the top !
DP
04-20-2005 12:07:17
It doesn't matter what brand you buy. Your warranty is only as good as the dealer that sold it to you.
