JD2010 Hydraulic problems
Jon
02-21-2004 12:50:19
I have a JD2010 gas tractor w/ a single hydraulic system. It has a single control for the 3 point and 2 remote hydraulic control levers. The 3 point works fine, but both of the remote control valves quit working. The power steering also works fine. When the remote valves did work, the front dump bucket would raise when uning the 3 point. I have changed the filter and it is full of hydraulic oil.
Tom in Mo.
02-21-2004 17:37:24
 Re: JD2010 Hydraulic problems in reply to Jon, 02-21-2004 12:50:19
John Deere service manual #SM-2035 covers almost everything there is to know about the hydraulics on the 2010's. If you don't have one, I would recommend getting one. I have seen 2010's with single main hydraulics and dual main hydraulics but only with single remotes. It sounds like you have dual hydraulics (lift arms) and only one of your three point lift arms is being used and the other (of your duals) is being used for a remote. Something to look into.
Bert
04-09-2004 19:02:52
 Re: Re: JD2010 Hydraulic problems in reply to Tom in Mo., 02-21-2004 17:37:24
hey tom in Mo,dont know where to start ,ok i,m also in So.Mo. i am looking to purchase a 2010 dont know anything about it sposedto run here is eng #stamped on block 56789 no kidding does this have (live ) power its a tryc. looks all there i believe it has a deal that hooks to one arm on pto that goes to just in front of clutch could be for a front loader??? are these tractors worth messing with?? i dont have too much work for it to do just a small farm LOTS of brushhogging please get back with me
