D mainfold
MDM
02-21-2004 12:16:04
would a 36 D benifit from having a gas manifold versus all fuel manifold?
Clooney
02-21-2004 12:47:00
 Re: D mainfold in reply to MDM, 02-21-2004 12:16:04
MDM, it would make a little more horsepower & possibly run a little better when hot.. If you have the DLTX-6 carb also replacing the carb load nozzle with the R10062R load nozzle will help even more.. If you added high compression pistons or raised the engine compression it would add even more..
~Not sure where you will find a gasoline manifold for that unstyled "D" but if you do that would make a nice conversion..
~There is another option & that is to add a dual pipe exhaust manifold from Rosewood Machine.. Those are supposed to add about 6+ horsepower..
[email protected]
