38 unstyled b
verne
04-19-2005 18:49:41
wont crank and run smooth. put on new carb set timing runs rough lot of black smoke wont idle very good. was resetting timing and have now lost spark. where is my problem?
Maark
04-20-2005 08:27:39
 Re: 38 unstyled b in reply to verne, 04-19-2005 18:49:41
You will probably need to adjust the carb. Even though it is new or rebuilt, the carb setting will need to be changed to allow your tractor to run properly. Too much black smoke indicates a rich mixture. You will need to turn the adjusting screws in until the black smoke quits. Usually 11/2-2 turns out.
Dave NE IA
04-19-2005 19:31:01
More details would probably help you. If you had the mag off did you forget the gasket, I had a old deer mag man tell me that years ago it was the first thing he checked. If you do not have the gasket it can bind on the impulse. I would strongly suggest you post back, with a back track of what you were doing in detail when you lost the spark. Does the impulse trip? Good Luck Dave NE IA
