50 stuck block
RustyAL
04-19-2005 18:11:23
After removing the head and cylinder block bolts the block is stuck. Are there any more nuts to remove inside the block? Or is there just a trick to removing the block?
buickanddeere
04-20-2005 07:10:43
 Re: 50 stuck block in reply to RustyAL, 04-19-2005 18:11:23
Undo the oil line at the bottom before tearing it off.
Mike M
04-20-2005 07:12:39
 Re: 50 stuck block in reply to buickanddeere, 04-20-2005 07:10:43
That operation is not needed on a model 50
buickanddeere
04-20-2005 08:04:10
 Re: 50 stuck block in reply to Mike M, 04-20-2005 07:12:39
Mike
Your are correct. I was thinking the of head to block, not block to crankcase.
RustyAL
04-20-2005 14:19:51
 Re: 50 stuck block in reply to buickanddeere, 04-20-2005 08:04:10
Thanks anyway. I have allready given a couple oil lines really good tugs before realizing they needed to be rmoved. One was going to the rocker and one to the crank bearing holder.
ChuckW
04-19-2005 19:13:13
there are two bolts under the block to the frame.
RustyAL
04-20-2005 17:50:44
 Re: 50 stuck block in reply to ChuckW, 04-19-2005 19:13:13
Block came off real easy after removing the bolts. Thanks again.
RustyAL
04-19-2005 19:27:34
And I am guessing the block will come out easier with the 2 bolts removed. Thank you for your help!
