4010 Oil Cooler. Last FYI
txgrn
04-19-2005 17:45:49
The cooler looks like aluminum. It's made of a solid gray material that doesn't rust. Some of you said it was aluminum. The welder tried to weld with alum and it wouldn't stick.
Confused, he got a magnet and it stuck. Magnets as you know don't stick to aluminum. But Tin is magnetic.....da ta da.
He brased it with a brass rod for $40..... ...
So If any of you folks have this problem with a JD oil cooler, before you throw in the towel and chew your fingernails off to the quick, or pay $500 for a new one (if you can find it) put a magnet on it and if it sticks, get out the brazing torch and the brass rod and GO FOR IT.
End of saga.
Mark
Jason Z in MO
04-20-2005 07:43:42
 Re: 4010 Oil Cooler. Last FYI in reply to txgrn, 04-19-2005 17:45:49
Mark,
As you said before the tank has a locating pin on the bottom and is clamped to the bands around the fuel tank.
On my 4020 the cooler sits on a piece of heavy webbing with a hole punched in it for the pin. I don"t remember you mentioning it before and I wouldn"t want you get a big ol hole in the bottom after a number of hours...
I got the piece of webbing from my dealer.
R. John Johnson
04-19-2005 20:15:30
Mark
Glad to hear you got her fixed.
John
txgrn
04-20-2005 06:48:50
 Re: 4010 Oil Cooler. Last FYI in reply to R. John Johnson, 04-19-2005 20:15:30
Thanks buddy.
Mark
KIP
04-19-2005 19:31:26
The cooler must have some iron or steel in it. Tin isn�t magnetic. I would bet it�s made of steel.
txgrn
04-20-2005 06:48:09
 Re: 4010 Oil Cooler. Last FYI in reply to KIP, 04-19-2005 19:31:26
Yeah, that's what I thought too till I decided to understand what tin consists of; having used it a lot in soldering but never understanding what it is.
Webster has a different idea, says ..... a magnetic substance..... .
So, it just goes to show you (us); pays to check it out when in doubt.
Besides, the welder jumped right on the magnet when the aluminum weld attempt failed. He must know his materials or had this problem before.....had the magnet handy.
I had some pretty good rub damage to the tank (deep groves) and it was obvious that this was not plated. It was solid whatever it was.
Mark
