720LP..Did I mess up or not? Cut head 50 thousands
Ben.So.Tex
04-18-2005 18:47:17
I had the head reworked, grind vavles, And the had the head plain, and cut 50 thousands off the head. Now while installing the pistons I notice that the piston comes all the way to the top.. Did I mess up by taking off the 50 thousands off the head?
George S. in the real NY
04-22-2005 00:42:59
 Re: 720LP..Did I mess up or not? Cut head 50 thous in reply to Ben.So.Tex, 04-18-2005 18:47:17
Whoa!!! I think you got something else very very wrong here. A few years ago I put 720 hi altitude pistons in a 720 and they did NOT protrude past the top of the block. These were brand new pistons right from Mother Deere. Are you real sure that the pistons are the right one for that tractor? Check and be sure the connecting rod is the right part. I could tell the story of an Edsel engine I got once that had two thick head gaskets on each side. Same sort of problem. As I recall the compression heigth, i.e. distance from center of the wrist pin to the top of the piston is the same on the gas and hi alt pistons. My tractor is a gas and I wanted a little more kick, so I got the hi alt pistons to up the compression a little. LP were not available. The only difference is the volume of the cavity in the top of the piston. I got a pix of the two side by side. Also, I tried something else, I left the two piston rings below the wrist pin off. Cars haven't used lower oil rings since the 50's and work fine. Hopefully without the rings, more oil will get up in the skirt area and keep it lubed and thus reduce wear. Also, less drag to start it. Tried a few times in the cold of winter and she fires the first time and runs great. I would expect that the .050 off the head would not be a real issue but you may be getting close to the limit.
Ted Dlugosch
04-20-2005 15:17:34
Ben, I am in CC, Texas and have a question about a 720 LP. Email me.
ChuckW
04-19-2005 13:07:47
I'm trying to figure out why you cut the head down? LP's have boocoo compression as is. Puzzled in Ky.
Drew
04-19-2005 10:12:18
If you want to get it back to where it was, put an extra gasket or two between the crankcase and the block to space it back out.
Mike M
04-19-2005 12:19:51
 Re: 720LP..Did I mess up or not? Cut head 50 thous in reply to Drew, 04-19-2005 10:12:18
I wouldn't do that as your oil rings may pop out the back of the block,they are probabaly close to coming out now.
Mike M
04-19-2005 06:48:31
I would say that if it were mine to put my mind at ease I would try a dry run assembly and bolt the head on without the gasket in.You will have to hook up the rocker arms and set the clearance. Then slowly turn the engine over by hand and see if it binds up,if not then the added clearance from the gasket should be safe.
Ben.So.Tex
04-19-2005 09:04:02
 Re: 720LP..Did I mess up or not? Cut head 50 thous in reply to Mike M, 04-19-2005 06:48:31
I check the head and piston and it should clear by about 1/2 inch. I didnot have the head at home yesterday, But when I saw the raised portion of the piston sticking out of the block it look bad, The raised portion sticks out about 3/8 inch and the well in the head at the shallow end is 1 1/8 inch.Thanks Ben
