4010 Oil Cooler Status
txgrn
04-18-2005 07:36:33
(For any one else that decides to tackle this having never done it before..... this is for you)
Decided to have a go at the cooler yesterday. Working alone, with a couple of 2x4's I got the hood up and turned sideways (around the exhaust pipe), so I could get at it.
Got real scared at first as there was no way to get to the bottom of the cooler to unbolt it from the tractor (pump and frame structure all over under there)..... ..only to find out later that only 2 easily accessible screws (easily seen from the side) hold the thing in place with a dowel pin for alignment on the bottom.
Got the upper hose off and the little vent hose. Tank wiggled but wouldn't come out. Got to looking for another tube as only saw one on the top and what goes in has to come out. Right?
Took the aircleaner out and was able to see and finally cut thru the lower one and got it out..... .after I stabbed myself in the hand with the knife I used to cut it.
Now what appears to be the good news. The tank pressure tested yesterday at 20 psig submerged in a tank of water. Great; but where is the leak. Suspect the lower hose had deterioriated. Sorta looks that way.
Will retest again today at 100 psig and if it passes whoopee..... .....
Since the cooling fan swirls such a large volume of air around the radiator, it very well may be that the hose was the culprit and not the tank to fin interface. Hyd fluid was everywhere and it was hard to tell. Will I be a happy camper if that's it.
Mark
Bob
04-18-2005 10:16:28
 Re: 4010 Oil Cooler Status in reply to txgrn, 04-18-2005 07:36:33
While you're in there, replace the 2 square cut "O" rings in the banjo fitting at the top of the pump (if so equipped). This would be the fitting the oil cooler outlet connects to. Those little buggers like to leak, and, as you say, with the rapid air flow through that area, it's hard to track down the origin of leaks!
txgrn
04-19-2005 07:46:18
 Re: 4010 Oil Cooler Status in reply to Bob, 04-18-2005 10:16:28
Thank you sir. Guess I'll mosey by the dealership when I go to town, have a look see at their IPB and get a couple. Better to do it now than to have to tear it all apart later.
Thanks again.
Mark
Bob
04-19-2005 08:42:19
 Re: 4010 Oil Cooler Status in reply to txgrn, 04-19-2005 07:46:18
tx,
Have you tried the Deere on-line parts catalogs?
R. John Johnson
04-18-2005 10:13:02
Mark
I had a hydraulic leak up front in mine a couple of years ago. While it was at my cousin's getting the clutch changed he fixed it. Can't remember exactly, but it had been either a hose or simply a hose clamp tht had worked loose.
John
txgrn
04-19-2005 07:43:18
 Re: 4010 Oil Cooler Status in reply to R. John Johnson, 04-18-2005 10:13:02
Thanks, R. John
Mark
Glen Anderson
04-18-2005 09:48:23
The flexible rubber hoses are most likely the culprits, when replacing them be sure to use the proper hose designed for oil use, however be sure to check all of the steel lines, both high and low press., to make sure they haven't rubbed against each other and created a hole - this is a very common problem we've noticed with these tractors that usually comes from not making sure the line separators are properly positioned and tight. Also, adding a piece of rubber and a couple of zip ties to any area where there may be potential friction between two lines is a good idea.
Good Luck
txgrn
04-19-2005 07:42:14
 Re: 4010 Oil Cooler Status in reply to Glen Anderson, 04-18-2005 09:48:23
Agree. There are 2 places heavily worn. I had already put rubber over the tubes but now that the cooler is out, I'll fill in the indentations with metal/epoxy.
The hose I'm using is Neoprene with double reinforcing and a 300# rating. Should hold up to the 180 psig of the coolant loop.
Thanks
Mark
