Tom, what ignition system you running, a Delco Distributor or what??? One set of points and condensor fires BOTH sides, so if ones firing but not the other, I suspect plug or plug wire or a cap or rotor or possibly a cam lobe diference (points must break open to spec on each high cam). If its an external coil ignition like a Delco Distributor (sounds like maybe from your description) first thing I would do is remove the coil wire from the cap (leaving coil end attached), remove the cap so you can observe point operation, and have that bare coil wire end to within 1/8 inch away from tractor steel, turn her on n crank her over, and see if EACH TIME the points break open the coil fires a spark across that open gap from coil wires end to tractor????? ? Insure the points are indeed closing down fully then open to spec on each high cam and the coil should fire each time they break open. Excess distributor shaft wobble or wear or a cam lobe problem might allow the points to close fully and open to spec on one lobe but not the other, check and try a wider points gap n see what happens. Nowwwww www if the coil is firing each time the points break open (you dont need the cap and rotor on to observe the points action and the coil can still fire) BUTTTTT TTT only one cap terminal (once its replaced), then its either the wrong cap or rotor or theres a problem in the cap or one of the plugs or one of the plug wires, which a swap out can eliminate. YOU SURE ITS THE RIGHT CAP AND ITS ON CORRECT??? If you look at where the rotor tip is each time the points are on a high cam, the internal cap pick up terminals MUST be lined up with where the rotor tip is at when the points break open. If it happens to be some sort of gear reduction drive ignition, they only run at 1/2 speed and if installed 180 out of time she could be firing but NOT when the rotor tip is in line with a cap tower and that side wouldnt fire. Be sure and find out if its ALWAYS just that one cap terminal thats not firing (like top or bottom) regardless of what plug wire or plug you use to be sure its NOT just a plug or plug wire thats bad. If she fires the coil on BOTH high cam lobes, however, but BOTH cap terminals do not produce spark (with good wire and good plug) then its gotta be a bad or wrong cap or rotor or its not for that distributor (rotor and cap terminals not lined up at firing) PS its not a Wico C magneto by chance (you mentioned a coil wire and it has that short lil one) if so post back for other things Lemme know, good luck n God Bless John T
