60 died
Dale13
04-17-2005 21:07:21
My dad was plowing with his 60,everything going good till he got to the end of the field and the plows wou;d not lift.Made a funny noise and then stalled out.Will not turn over,will not turn over even being towed.Any ideas??
Mark Scholten
04-19-2005 03:10:05
 Re: 60 died in reply to Dale13, 04-17-2005 21:07:21
I am leading towards the hydraulic pump idler here also. Check the pump housing and see if there is discoloration from heat. Mark
KS Baker
04-18-2005 09:31:34
Had that problem once or simular. We used our old 60 on a log spliter and took the seal out of the hydralic pump. This dumps all your hydralic oil in to the crank case. It did not kill mine but made her pull down and labor. Got it shut off quick and started looking. Check your oil level in the crank case if it"s way over full, I"d say that was it. The parts weren"t that exspensive. Took a couple hours to repair. Get a manual so you have the specs to check the shaft diameter. Borrow a micrometer our take it to local machine shop to measure. If I recall your only allowed 0.001 or 0.0015 of wear on the shafts and gears.
I could be wrong on that though. It"s been almost ten years. Hope this helps.
Ken
buickanddeere
04-17-2005 21:16:12
Did it have oil pressure when it she quit? What was the coolant temp? Any chance some s.o.b.put sugar in the fuel tank?
Dale13
04-18-2005 02:46:51
 Re: 60 died in reply to buickanddeere, 04-17-2005 21:16:12
Had oil pressure,not sure about coolant temp or sugar.He feels that the hydraulic's died first than motor died out.
buickanddeere
04-18-2005 07:03:55
 Re: 60 died in reply to Dale13, 04-18-2005 02:46:51
Sounds like it's time to have a look under the flywheel side. Perhapes the hydrauluc pump idler gear seized, twisted off and jammed/busted everything else. Unless you count on repairing the tractor. It's worth way more, is less mess, less time & agrivation. Not to tear it down into a pile of parts then give up on it. It will sit around for years. When selling it, the purchaser has to figure on rounding up all the replacement lost and rusted parts.
Dale13
04-19-2005 05:54:46
 Re: 60 died in reply to buickanddeere, 04-18-2005 07:03:55
Hauled it back to the shop and did a little quick checking over.Engine turns over but distributor does not.So yes it would seem it's what drives that the governor and the pump. Will post more when it gets torn down.
