3 point on 4020
SMA in NE
04-17-2005 20:21:27
My 3 point hitch will not raise at all when the setting is on depth control, it will raise when set to load control. Does anyone know why this occurs? Load control does not give accurate enough height position for mowing.
msb
04-18-2005 21:52:06
 Re: 3 point on 4020 in reply to SMA in NE, 04-17-2005 20:21:27
If the 3 point is going to work at all,it will work in D.Are you sure it isn't in Load that is where it won't work? Depth is all the way to the bottom.
If this is the case, repost next evening and I or someone will walk you through the adjustments.Its not hard to properly adjust the linkage.
Hayfarmer
04-18-2005 07:36:29
I worked for the JD dealership here at the time the 4020 and 3020 were relatively new. Tere is a series of adjustments to the 3 point that have to be followed in sequence. It seemed that they got out of adjustment a lot. See if you can borrow or pick up a service manuel. One of the adjustments as mentioned is through a plug in the back "bunghole" adjustment as it was referred to (not by JD). That takes a long extension and deep 9/16 socket taped or otherwise securely fastened to the end. You definitely don't want the thing dropping off inside.
thurlow
04-18-2005 04:23:18
I suppose it could be a mis-adjusted control cable (or there is a little bit of adjustment available inside the rockshaft control valve housing..... which can be done from the outside through plug above serial no. plate), but sounds like the cam follower is off track.
