A rod bearings
Eli
04-17-2005 15:54:50
I checked the rod bearings on my newly purchased A. Number 2 is good. Number 1 has a new rod. Number 1 journel measures 2.994 rod bearing measures 2.998. My knowledge says this should be good, however number 1 has nothing where the shims should be. How can this be a like new crank journel if new was 3.00 and like new bearing. Are there after market rods that didn't use shims? Is a new crank journel 3.00. Help. Thank You Eli.
Mike M
04-17-2005 18:58:00
 Re: A rod bearings in reply to Eli, 04-17-2005 15:54:50
It could have an insert bearing type rod installed and they don't use shims.
Eli
04-17-2005 20:51:08
 Re: A rod bearings in reply to Mike M, 04-17-2005 18:58:00
Yes it does have insert type bearings. So I must order one a couple of thousands smaller instead of taking out shims? Thanks for the help, Eli.
