530 JD-lost engine oil pressure
Chris Stuva
04-17-2005 07:30:04
I was using tractor. Good oil pressure for 2 hours and just quit. Tried to start, but will not build pressure to get engine shut off to fire. Pulled filer and no filings. Has anyone ever run into this before.
Thanks for the help
Tyler-MO
04-17-2005 09:06:21
 Re: 530 JD-lost engine oil pressure in reply to Chris Stuva, 04-17-2005 07:30:04
You can check this by taking off the crankcase inspection cover...might want to get a new gasket first...you will need it...it's cork
once you take it off....you should look for a shaft going down from your camshaft into the oil pump....there is a square box coupler there...if it's broken it will be obvious...or it might have fallen off and will be laying in the oil sump. GOod luck...if this is the problem...you can pull the oil pump out of the bottom...but the lines can be a real pain to get lose and especially to attatch...but it can be done...get a helper with small hands
Good luck!
Tyler in MO
old
04-17-2005 08:15:47
Had that happen on a B, the oil pump drive broke. On a B its not hard to fix on yours I'm not sure, don't even know if the oil pump coupler is like that of a B just an idea for you to check.
