45 Loader won't raise
Randy G.
04-16-2005 21:52:39
My 45 loader raises no higher than the nose of my "55 50. Has plenty of oil, sometimes shoots out of the resivor tank. Sometimes it will raise much higher. When it doesn"t, if I race the engine it inches up very very slowly but not fast enough to use. What should I look at to cure the problem?? It is hooked up to 1 pioneer coupling that pulls out rather easily. Your recomendations are needed!!!
Obiwan
04-18-2005 15:53:59
 Re: 45 Loader won't raise in reply to Randy G., 04-16-2005 21:52:39
I had the same problem on my 60 with a 45 loader. Thought it was the internal seal on the hydraulic pump, but that didn't fix it. Turned out to be old oil, which had picked up water through condensation over the years. Check for foamy oil after trying to raise the loader. If you have that, an oil change may be an easy (if not dirt cheap) fix. Good luck.
cannonball
04-18-2005 05:03:13
if it is one way cyl, is the vents plugged if so you might have fluid bypassed and locking it up or you are compressing air and once you get the air compressed to pressure your pump is putting out then it stops.....have nice day may god bless
Mike M
04-17-2005 13:41:21
Those are one way cylinders,BUT you will need to hook up two hoses to each on that model tractor as you are running out of oil. The front of the cylinders are used to hold extra oil capacity.
Randy G.
04-17-2005 08:15:56
The cylinders are 1 way I believe. They lift but gravity pulls it down.
Hayfarmer
04-17-2005 12:37:41
 Re: 45 Loader won't raise in reply to Randy G., 04-17-2005 08:15:56
Does it squeel when it gets as high as it will go or just labor? If they are 1 way cylinders and packing was leaking oil would run out the bottom of the cylinders when you let it down. and it probably wouldn't come down well. Have you used the hydraulics on other stuff like 3 point or lifting an implement? Does it make a difference if you have a load on it? If you have to reace engine to raise it higher perhaps the pump is low in pressure, you might need new seals or rebuilt there. Quick couplers will cut down on flow rate also but should still get pressure.
ET
04-17-2005 03:17:41
If you have two way cylinders a piston packing is probably blown and oil if flowing by internaly.
