Dan, quite few years ago we were getting coolant in the crankcase on our 40U, in addition, the tractor was hard to start(spark plugs were allways wet), we found the cyl. head was cracked between the valves down into the intake and exhaust ports. The cracks were small and hard to see so I built a pressure testing plate for the cyl. head so I could confirm that the coolant was actually coming from these cracks - some cyl. heads are not affected by cracking between the valves but the 40 isn't one of them - if it's cracked it's likely where the coolant in the crankcase is coming from and you'll have to replace the head. If nothing shows up on the cyl. head, the block may be cracked, I've heard of 40 blocks being cracked in the past but I never seen them first hand and I couldn't tell you where to look, although I'm sure some of the other fellows on the forum have encountered this before. On the oil press. issue, if there was enough coolant, antifreeze specifically, in the oil, that may answer for the low oil press., however the antifreeze will damage the bearings and it may be good idea to inspect their condition and replace accordingly before operating the tractor any longer. Inspect the condition of the oil pump as well. I believe the oil filter system on the 40 is of the partial flow or kidney loop design meaning only a portion of the oil that the oil pump produces is filtered. All main internal engine components(main and rod bearings, rockershaft, etc.) are supplied with unfiltered oil directly from the oil pump, any excess oil flows through the filter and back to the engine crankcase, therefore it MAY not be the end of the world if you don't notice any oil in the filter housing. As Roy mentioned these engines are easy to work on, very simple, and very forgiving. Compared to wrenching on some of the newer equipment being produced, the 40 is quite a treat! Good Luck!
