Changing a late B from WICO to Delco
wilamayb
04-16-2005 18:52:24
I am planning on changing my late B from a Wico XB to a Delco distributor to save myself many headaches and also to lower my blood pressure!!! LOL!! What I am needing to know is what parts will I need? Distributor, external coil, something to hold the coil, hold down clips for the distributor,What else?? What type of coil do I need? What type of coil holder can I get to give an almost "factory" apperance? If there is anything I should know about changing it please let me know. Thanks so much.
John T
04-17-2005 08:14:14
 Re: Changing a late B from WICO to Delco in reply to wilamayb, 04-16-2005 18:52:24
The coil you buy needs to be for what voltage your battery is. If youre at 12 volts you can use a full 12 volt rated internally ballasted coil ORRRRR RRRR you can use a 6 volt coil plus an external voltage dropping series ballast resistor. If at 12, I would go with a full 12 volt rated coil and not have to mess with any external ballast. Sounds like you have the hardware down, coil and mount, distributor.
John T
