JD 50 running pretty cool.......
Tye W
04-16-2005 17:48:34
Just put a new water temperature gauge in my 50. I did some pretty heavy discing for about 20 minutes this evening and I can"t say I saw the needle come off the 140 degree mark. The air temperature was about 50 degree this evening. Is this something to be worried about or can I expect the temperature to rise when summer rolls in? Thank you for any input.
Tye W
04-17-2005 05:56:13
 Re: JD 50 running pretty cool....... in reply to Tye W, 04-16-2005 17:48:34
Thank you for all the opinions. Have a great day!
payne
04-17-2005 05:26:23
My dad has a JD 50 Lp that i put the water system back together on and there was no thermostat or a place for a thermostat. If you look in the parts manuel they made some with thermostats, shutters, and then some with nothing. You probably have this or your thermostat isn't working. Either way we run our deere at around 140 and it still runs great.
buickandeere
04-17-2005 06:02:09
 Re: JD 50 running pretty cool....... in reply to payne, 04-17-2005 05:26:23
Running at too low temps is early death of a gasoline or diesel engine. The vapour fuel from LP will slow down the early destruction. Two 50's at home. One with stuck shutters and worn pistons,rings, cylinder walls and carboned up everything. The other 50 without the bypass line hit's 180 with the stat in it. Even just putitng around the yard or at shows will show 180F in 5 minutes. The 180F machine runs smoother and burns less fuel. Exhaust doesn't stink as much either.
John Van Valkenburgh
04-17-2005 00:18:10
I think it depends on which cooling system you have. The older 50s like mine use shutters on the radiator which are connected to a linkage and thermostat in the lower radiator casting. Many of these old machines have the shutters removed (mine did). The shutter arrangement had problems with sticking and was later replaced by an automotive type thermostat arrangement.
The later automotive-type thermo arrangement is much better and allows the engine to warm up more quickly. This style cooling system will have a little bypass hose on the water pump. If you have the later style automotive-type thermostat then I'd suspect that it may be stuck open or removed.
The older shutter systems take forever to warm up even when the shutters are closed. All the coolant in the system must heat up at the same time. Something like 6 or 7 gallons! I put shutters back on my 50 but I control them manually and don't open them till I get up near 200. Getting the engine properly warmed up helps to vaporise crankcase condensation.
So...
See if you have the newer style thermostat system. If so, it may be stuck open or removed. If you have the older style system see if you have shutters. If you do have shutters, see if they close when cold.
Best of luck,
John
1953 Model 50
BushogPapa
04-16-2005 22:18:56
You probably need a new Thermostat...
It should have at least hit 160 to 170, if the thermostat is working properly...
Ron.
55 50
04-16-2005 18:45:47
Mine runs about the same temp. I have a new radiator and all the passages were cleaned very well while it was apart so it isn't getting warm enough to even open the thermostat. Mine is a 55 with the thermostat right up by the top tank and it has the bypass pipe back to the water pump.
