Calcium for adding wheel weight
Charlie M
04-16-2005 15:15:22
I had an earlier post looking for information on finding out if I had inner tubes in my rear wheels but got many comments regarding my plan to use calcium chloride, most saying not to do it. I looked at the JD owner's manual for my JD1530 and here's what it said under the adding ballast section:
"Water and calcium choloride solution is an economical means of adding weight to the wheels. The additon of calcium chloride is recommended to prevent the water from freezing.
Use of the method of weighting the wheels has the full approval of the tire companies. See your John Deere for this service. The following chart lists the liquid weight each tire will hold when 75 percent full..."
This manual is from the early 70's and doesn't mention anything about corrison. Could this be that it is assumed that it will be only used with an inner tube? Have other's had success or problems using calcium?
Thanks for any comments.
Mike M
04-17-2005 19:11:02
 Re: Calcium for adding wheel weight in reply to Charlie M, 04-16-2005 15:15:22
They got some new stuff out called rim gard it is made from beet pulp. Check with your local tire dealers.
630rich
04-16-2005 20:25:57
some farmers around here use Anti-freeze mixed with water,or windshield washer soultion..mixed with water...
thurlow
04-16-2005 19:25:20
CaCl is a nothing but a salt; been used for many decades just as your manual suggests; it will rust your rims if it's allowed to get to them. I would suggest you go down to the tire store which services the tires for the local farmers and see what's being used in your area; almost assuredly all the farmers around "there" are using the same stuff; whatever it is. "Here" it's alcohol/water; may be different a few counties over.
Hayfarmer
04-16-2005 19:23:19
In my part of the country, Washington State, I have seen very few tractors, the larger ones anyway without Calcium in tires. I see very few add on wheel weights. When I worked for the JD dealer here most of the new tractors went from the dealership to the tire store for calcium before going to the field. Guess the guys didn"t worry as much about rims rotting out as they did the extra traction.
Ken in Mich
04-16-2005 18:00:08
Why dont you call your JD dealer and ask. As I said before, the rim saver (beet juice) is what my JD dealer put in mine. Why put in something that might give you trouble donw the road, when there is a much better product available?
Leroy
04-16-2005 17:32:36
And I will have more Calcium put in my tires IF I can find it, Any of you guyes close enough for me to get it when you drain it? Absolutaly no use for me to worry about rust as my one tractor has had it in sinse Dad was able to first get it and that tractor is a 44 model and I expect the rims to outlast me and I am 61 years old
RonMC
04-16-2005 16:34:10
I've had CaCl removed from all my tractors that had it. The reason ? I didn't need it. If, however you are doing pulling or heavy field work and rims are readily available for your tractor, it can be a cheap and useful way to get the weight. The problem I found with it was that a lot of times the wrong valve cores are put in - the ones with the spring on the inside and exposed to the solution. They will rot the spring in short order and cause a leak at the stem. The best kind of valves for the application have the spring on the outside shielded from the solution. If you use these and new tubes it will be OK for a lot of years. In my position; with vintage tractors, rims not readily available if you do get a leak, I'd find a mechanical (wheel weight) way to achieve the same thing. I had 800 pounds removed from my AR before transporting it from Saskatchewan to B.C. as it wasn't needed here at home and it costs a lot of fuel to haul that weight over the Rockies. I suppose you'll figure out what is best, but the rim rot and un-needed weight has been my experience. Hope this helps, Ron
Gerald J.
04-16-2005 15:47:13
Tire sidewall split, pinched tube, sprayed CaCl over me and the tractor which rusted under the paint instantly. Things like the brake pedals sharing a shaft haven't worked right since. New tires pulled better without weight than the old tires. No tractor of mine will use CaCl for weight.
Gerald J.
fixerupper
04-16-2005 20:39:34
 Re: Calcium for adding wheel weight in reply to Gerald J., 04-16-2005 15:47:13
A rim split on my 1086 and shot fluid up under the cab. In a month I had ALL of the shifting linkage on top of the tranny rusted up. Took a day of reaching through the cab floor removing linkage, shining it up, greasing it and putting it back in. When the tire man came to put the tire on the new rim I had him suck the fluid out of the other tire. Now it has three weights on the inside of the wheels and four on the outside. It rides smoother now too.
John51
04-16-2005 15:45:50
Sure, it adds cheap weight. And it doen't harm tires. But the stuff is mighty hard on rims. If you NEVER have a leak, it's OK, but that means watching your valves and changing them before they start to leak. My advice....either use cast weights or a non-corrosive liquid for ballast. I will never use calcium chloride again in my tractors.
Hoosier JD
04-16-2005 18:43:55
 Re: Calcium for adding wheel weight in reply to John51, 04-16-2005 15:45:50
I've read posts and more posts about what to put into tractor tires for weight. Here comes my 2 cents... when we farmed, Grandpa and Dad refused to use calcium for weight, they, for several reasons used mechanical weight or did without. Long story short, Grandpa passed on and Dad had to quit for health reasons....I was too young to take over so went to work for the area farmers. Most of them did not use calcium, just used mechanical weights. I got old enough to go to college, went to work in a tire store to put myself through school. Learned alot about calcium as I mostly took it out to do repairs on tractor tires...then left it out at the request of the farmer. They usually cussed at the stuff. It would eat a good pair of Wolverine workboots in about 6 months, I finally learned to wear rubber boots. The stuff ate anything that was not rubber, stunk to high heaven as it was being handled, took your breath away if you happened to have to mix a new batch, and on and on. Now I understand that there are several alternatives to calcium (it has been along time since I worked at the tire store) and maybe those are okay? I just know that I did not like to handle it and did not like putting it into tires. By the way, I never put any calcium into any tires without tubes. If I were farming, I would find some other way to weight a tractor down. Thanks for letting me vent. Do what you gotta do! Good luck, Mike
