Help with '49 A rebuild
tractordave
04-16-2005 12:42:13
I am rebuilding a 1949 Model A SN 626354. It was apart when I got it. I have all the manuals. It looks like I have an oil line on the tappet assembly, I think it goes to the fitting on the valve cover, where does it go from the valve cover to? I do not see any tubing to attach here nor any hole where I would route a new tubing to.
Does anybody know of a book that will show the late A in exploded drawings or go over rebuild step by step? The manuals I have are not very detailed and cover several different years and serial # ranges, making it more difficult to determine what is for my year and what is not...
Dave
tractordave
04-16-2005 16:35:05
 Re: Help with '49 A rebuild in reply to tractordave, 04-16-2005 12:42:13
Thanks for the reply. After I wrote the question I went back to the books and found that the fitting on the valve cover is for the vent tube that goes in the air intake. So If I have this straight the oil comes out of the head, drips onto the valves and collects in the bottom of the valve cover where it is returned in the holes in the bottom of the head?
Dave
Mike M
04-17-2005 13:49:17
 Re: Help with '49 A rebuild in reply to tractordave, 04-16-2005 16:35:05
Yes.
Mike M
04-16-2005 14:42:42
That oil line on the tappet assy. hooks to a fitting that is in a thick cast iron washer that goes over the center head bolt stud. The head has an oil pressure passage and also return oil drain holes. I think there are two different styles of washers depending on which cyl. head you have. Just make sure the pressure passage is sealed and not open to a return hole and that the return holes aren't blocked off.
