2840 starting problems
Chuck MI
04-16-2005 06:39:48
My brother is working on a 2840D of our cousins which from time to time doesn't want to turn over. Sometimes if you turn the stearing wheel some, it will go ahead and start. Is it possible that the power stearing pump has pressure built up that is causing extra resistance to the starter motor? Is there a release that could be blocked? It is a real stumper.
Any ideas and help will be greatly appreciated.
Chuck
Tx Jim
04-16-2005 10:04:38
 Re: 2840 starting problems in reply to Chuck MI, 04-16-2005 06:39:48
Chuck,the power steering gets it's pressure from the main hyd.pump at frt. of tractor.While cranking the main pump can build up pressure adding to load on starter.A destroking screw can be installed in pump to eliminate problem.Deere makes a manual or electric destroking screw.Tx Jim
Bob
04-16-2005 11:35:32
 Re: 2840 starting problems in reply to Tx Jim, 04-16-2005 10:04:38
As TxJim says, the front pump is trying to build pressure while you are cranking, putting a load on the starter.
When you rock the steering wheel back and forth, this uses oil from the front pump, and keeps the pressure down, allowing easier cranking.
Having a good battery of adequate cranking amps capacity, with a properly functioning charging system to keep it fully charged, clean connections, good cables, and a starter in tip-top condition will minimize the effects of the load from the pump, and give faster cranking.
If all else fails, Deere sells an "electric destoking kit", which is an electrically operated hydraulic valve that attaches to the front pump to make the front piston pump stay "out of stroke", so it isn't pumping oil while the starter is cranking the engine. Wires from that valve connect across the starter solenoid, so the valve is in "destroke" position as long as the starter is being activated.
Chuck MI
04-17-2005 18:53:20
 Re: 2840 starting problems in reply to Bob, 04-16-2005 11:35:32
Thanks for the info, we'll check on that.
Chuck
