I don't quite fully understand your post, but there could be a few simple solutions. The first that comes to my mind is that the facing behind the clutch driver could be out of alignment. If the pulley end play gets to far out, that facing can drop out of place and wedge between the pulley and the driver. I've seen this one happen twice before. In one instance, you couldn't stop that pulley with the brake to save your neck. Another possibility is that the pulley brake is not adjusted properly. This usually causes the clutch to re-engage as the clutch lever is pulled back. On the fit of the clutch facing disk, I haven't worked on a 620 clutch, but they are all very similar. If that disk is indeed installed on the adjustment bolts, that could be your problem. You are saying that alignment studs are too short to install it on them, this would lead me to rear clutch facing problem. If that facing is wedged behind the clutch driver, that would take up more space effectively making your studs shorter as the clutch would sit out further in the pulley. If you haven't totally disassembled that clutch, now is a good time. Other than getting the clutch driver off, it's a simple job. Take a look behind the clutch driver and see if that facing looks okay. If it is out of place, you will be able to tell as it will be pretty chewed up.
