JD 1020 blow-by?
Sam
10-24-2003 19:15:44
Hello, I bought a 72 diesel JD 1020 couple of weeks ago. It starts and runs easy, smokes a little and than it clears after warming up. It does not get hot and seem not to use much oil. How much exhaust is ok from the valve cover? I am not familiar with diesel engines and don't know what constitutes a 'blow by'? One other thing,I have noticed that it's hard to take off when the left shifter is in II position and the right one is in third or fourth gear when I am in the field.. May be it will work better on the road. All comments are appreciated. Sam
Steve - IN
10-24-2003 23:52:02
 Re: JD 1020 blow-by? in reply to Sam, 10-24-2003 19:15:44
Sam,
Blow by is when the "stuff" that's compressed at the top of the piston compression stroke finds its way down into the crankcase, and then out the rocker cover pipe. The cause is weak compression rings. To test for "how much" you have, do a cranking compression test or a "leak down" test to see how much compression you're losing. For practical measures, are you really down on power, or does the tractor seem to be able to do most of the things you ask of it? If the later, don't worry a whole lot.
The 1020 has 8 forward speeds. By going from a dead stop to 7th or 8th gear in soft terrain, you're asking a lot - and I wouldn't do it much to save wear and tear on the clutch. You'll have to slip the clutch and/or feather in the throttle as you bring in the clutch to get things rolling. Hard surfaces like roads, will give less rolling resistance, so it will be easier to do in that case. That's why they call those top gears "road gears". Simple, huh?
Have fun with the 1020, they're great little tractors.
Sam
10-25-2003 10:36:30
 Re: Re: JD 1020 blow-by? in reply to Steve - IN, 10-24-2003 23:52:02
Thanks Steve, You can tell that I am not very good with this stuff. I do not think this thing has much problem with compression because it will loose traction before the engine slows down. This is my first 'modern' tractor (my other tractors are from 40's & 50's) and I am concerned not to harm it. Part of my problem is that the seller is suppose to mail me the manuals of this thing and he has not done so yet. Besides the 8 speed this thing also has a lever on the left side that can make it go fast/slow.. I have not had a reason/chance to use that.. IS there a chance you can email me you email address, since you seem to be really experienced with this tractors..... Thanks again, Sam
Steve - IN
10-25-2003 16:12:06
 Re: Re: Re: JD 1020 blow-by? in reply to Sam, 10-25-2003 10:36:30
Sam,
Sure, the email addy is right above. My 1020 doesn't have the hi/lo shift option - but david val has given you a good explanation of the thing. I think you could also get a forward / reverse shifter stuck in where your hi/lo is. Really wish mine had that, as it would be great for loader work.
david val
10-25-2003 12:02:20
do you mean left hand side under the steering wheel? ('miroring the throttle lever?)
this controls the high-low shift unit. you can shift it 'on the go' and under load without clutching. shifting from high to low will reduce speed almost a full gear down. while tilling in high, if you encounter a tough spot, you pull the lever to low, get the extra power for the tough spot and return to high when your'e over it.
you also get 16 speeds for pto work (although not equally spaced.
its very important to keep the level of transmission oil and change filter on time.
NEVER try to tow start the engine!!! you can 'kill' the hi lo unit.
david
Sam
10-26-2003 11:40:58
 Re: Re: Re: Re: JD 1020 blow-by? in reply to david val, 10-25-2003 12:02:20
Thanks David and Steve.
