DLTX 10 CARB
TIMAR
04-15-2005 18:42:45
Another ?. Can a person repair in any way the threads that the bowl nut goes on? I rebuilt my carb and the threads out on the end are corroded enough that when the bowl gasket is put on I cannot draw it up tight with the nut. I can without the gasket in. Could a person use a liquid oil proof gasket instead?
CRUSADER
04-16-2005 19:28:09
 Re: DLTX 10 CARB in reply to TIMAR, 04-15-2005 18:42:45
There is a man in Nebraska that makes a repair kit for this carb. I bought one hoping to adapt it in order to repair a DLTX 67 for a J.D. 630. After looking at the replacement part and the carb, it's not going to work. If interested, I can send you the guy's name and phone number or send you the repair part that I have for what I paid for it.
later days mate,
Jim
Duane Larson
04-16-2005 06:47:35
TIMAR,
The proper way to fix your problem is to replace the neck. I use the bottom of a W18 Champion plug, which is the same thread size as the present neck, and has close to the same ID (which allows the nozzle to be removed/inserted). However, it is critical to have the new threaded piece perfectly aligned with the old neck, or else when the bowl nut is tightened neither the bowl will seat properly, nor will the bowl nut seat properly, and leaks will occur. I use a jig to hold the carb, and face the old end off in a lathe, as well as the new bottom. Then bevel both ends, and I braze the new piece to the old neck, using another jig to ensure the new piece is properly aligned.
However, if you want to try other things, you can remove a small amount from the top of the bowl, and get a new bowl nut (which has sharper teeth). The seal at the top of the bowl is an air seal, as the fuel level should be 3/4" below the top of the bowl. You can make a thin gasket for this purpose, but be aware that several of the silicon gasket makers don't work well around gasoline (some will slop up to the top of the bowl).
Dan-CA
04-16-2005 00:40:13
If you know someone who welds for a living(real professional)who knows how to do it on a carbuerator safely, it can be repaired. He will need to use the threads from a spark plug, 18mm, I think. I have heard that this works. Good Luck.
