F.I.T. ELECTROLOSIS??? FUEL TANK
TIMAR
04-15-2005 18:31:20
Can a person put a whole gas tank in this solution? I have used it for everything else but not anything with solder. Wonder if it would take the solder loose.
msb
04-16-2005 07:39:38
 Re: F.I.T. ELECTROLOSIS??? FUEL TANK in reply to TIMAR, 04-15-2005 18:31:20
I use muratic acid or hydrochloric acid if it is the same price.The only fifference is the dilution strength.Flush with water after use and then neutralize the acid with a box of baking soda after rinsing.It will even take the old lead deposits out.
RalphinWI
04-15-2005 20:33:13
I would not use it on a gas tank for my tractor. Is the interior of those tanks zinc plated? If so, caustic will remove the zinc about as fast as an acid will remove the zinc. I'm pretty sure caustic or lye will take the lead in solder, I'm not sure how fast. It readily dissolves lead sulfate and lead dioxide found in battery plates boyh of which survive a lifetime immersed in sulfuric acid.
