D fan bevel gear lash test
JGC
04-15-2005 08:57:45
Someone posted a calculation (or procedure) for checking fan shaft bevel gear lash by observing the amount of rotation of the fan blade at the blade tip.
Can someone describe a good procedure for determining this. I have to remove the shaft and water pipe, so now would be a good time to check the gear lash.
Thanks,
Jon
Duane Larson
04-15-2005 09:26:08
 Re: D fan bevel gear lash test in reply to JGC, 04-15-2005 08:57:45
JGC,
Before you remove anything, check rotation of the fan. According to a service manual published by the Columbus branch house, for all JD tractors the desired gear backlash is 0.004 - 0.007", and this corresponds to a movement of 1/4 - 3/8" at the tip of the fan blade, with the governor shaft held from rotating. Backlash is adjusted by the number of gaskets/shims under the flywheel side governor shaft bearing.
The gears must also have the proper heel - ie, the outer edges must line up. This is done by adjusting the number of shims/gaskets under the cap which attaches the fanshaft to the governor box.
JGC
04-15-2005 10:00:34
 Re: D fan bevel gear lash test in reply to Duane Larson, 04-15-2005 09:26:08
Hi Duane,
Thanks for the rapid response. I'm sure the branch house folks spent a lot of time checking this procedure, but check out my thought process below.
My "D" fan blade has a 9.5" radius - shaft center to blade tip. Assuming the bevel gear has a 1" average radius, .004" to .007" at the gear tooth should be .038 to .0665" at the blade tip. What I'm I missing.
Jon
PS. I found an easy way to temporarily "lock" the governor shaft so that I can be sure that the gov shaft isn't rotating and messing up the lash measurement. I carefully bottomed two long-threaded bolts thru the mag drive flange against the gov casting and then carefully tightened down two plates across the mag mounting face to hold everything firm.
Duane Larson
04-15-2005 19:56:28
 Re: D fan bevel gear lash test in reply to JGC, 04-15-2005 10:00:34
Jon,
I would think the average radius for the bevel gear would be larger than 1" - did you measure it? If it was 1.5" the JD info would be about right. I don't have a D bevel gear to look at (mine is inside the governor box and I hope will stay there :) ).
RalphinWI
04-15-2005 20:25:06
 Re: D fan bevel gear lash test in reply to Duane Larson, 04-15-2005 19:56:28
If the branch house was talking about the movement of the fan blade tip, wouldn't that include the play in all members of the gear train rather than just the bevel gear? I am assuming that moving the fan would move the camshaft, but not the crankshaft.
Duane Larson
04-15-2005 21:37:05
 Re: D fan bevel gear lash test in reply to RalphinWI, 04-15-2005 20:25:06
Ralph,
No, they were specific in requiring the governor shaft to be held stationary.
jgc
04-16-2005 04:51:00
 Re: D fan bevel gear lash test in reply to Duane Larson, 04-15-2005 21:37:05
1. It makes sense to "lock" the governor shaft because otherwise you would be adding an indeterminent amount of lash from the Idler gear teeth and it's bushing. (The camshaft drive gear is below the crankshaft and is not in this gear-train.)
2. If the mean diameter of the fanshaft drive gear is 2 inches, then the multiplier would be 5 to 1 (10" to 2") making the fan-blade tip travel .007" x 5 = .035". My gearlash is ~1/8" or .125" at the blade tip. The backs of the two bevel gears are not quite flush but it runs quiet so I'm tempted to leave it alone!
Jon
Duane Larson
04-16-2005 09:39:19
 Re: D fan bevel gear lash test in reply to jgc, 04-16-2005 04:51:00
Jon,
I can't reproduce the Columbus branch numbers either with any reasonable assumptions about the driven gear, and my old I&T book lists a fan movement of 1/8 - 3/16" at the tip. I have about decided neither group who wrote the manuals knew how to calculate the fan tip movement and so "just a little" would be fine. Those that have an inch or more movement are the ones with a problem.
JGC
04-16-2005 18:53:12
 Re: D fan bevel gear lash test in reply to Duane Larson, 04-16-2005 09:39:19
Duane,
Thanks for the dialogue on this subject. I appreciate your inputs.
Jon
RalphinWI
04-16-2005 22:22:23
 Re: D fan bevel gear lash test in reply to JGC, 04-16-2005 18:53:12
Likewise!
