830 transmission help needed
chrisfromsolitude
04-15-2005 08:22:18
I have an 830 tore down and the differential wobbles side to side about 1.5 inches. It was moving on the shaft that should have been pressed in. Also the gear that drives the ring gear on the differential is loose on it's shaft. My question is; do I put it back together or do I need to fix something? This tractor is still a workhorse on a farm and does most of the planting and some tillage work. Had an axle bearing come loose and the rollers got up into the gears. Thanks for any info
David from Kansas
04-15-2005 17:16:44
 Re: 830 transmission help needed in reply to chrisfromsolitude, 04-15-2005 08:22:18
Chris, where are you located? I have a 820 parts tractor and it still has a complete transmission and rear end, to include axles. Would be willing to sell any parts.
chrisfromsolitude
04-15-2005 22:08:58
 Re: 830 transmission help needed in reply to David from Kansas, 04-15-2005 17:16:44
I'm in southern Indiana. I'll keep it it mind. Thanks.
buickanddeere
04-15-2005 11:31:34
Fix it or you will back into it to replace many parts instead of a few. Check the parts book. Some parts cross reference right back to an "R". Cheaper to strip parts of one of them R's instead of another 830.
