2440 fuel guage????
Indydirtfarmer
04-15-2005 03:03:10
Last week, as we were finishing up with planting a corn field, the fuel guage on my 2440 started doing some strange things. At higher rpm's, or higher ground speeds, (on the road) it would start flipping back and forth between full and empty. Yesterday, I had to do some bush hogging. Started up the 2440 again, and this time, the fuel guage shot straight to empty. (With a FULL tank) Shut off the tractor, and it goes to full. Start it up, and instantly at empty.
Obviously, there's a problem.
How do I go about diagnosing the "cause". How do I check, (1) the sending unit, (2) the guage. I'll check the wiring between the 2 today when i get home. Also, is that guage "fuse protected" in any way.
I've got the owners manual, shop manual, ect... Just haven't had time to look at them yet. I thought that maybe someone could clue me in on what to look for.
Thanks in advance,
John
Jake
04-15-2005 19:03:09
 Re: 2440 fuel guage???? in reply to Indydirtfarmer, 04-15-2005 03:03:10
On those tractors the fuel gauge itself also needs to be grounded to the dash. And the dash needs to be grounded to the rest of the tractor. Check it's mounting for rust and corrosion and loose fasteners.
John T
04-15-2005 08:49:02
Indy Neighbor, I dont know beans about the gauges after they went over two cylinders, but heres how the old ones worked. Voltage was applied to the Gauges input when the power or ignition was turned on,,,,, ,,,then current flowed through the gauge (the amount of which determines needle deflection),,,,, ,,,,, to the sender,,,,, ,,,through the senders variable resistor,,,,, ,,,,to frame ground.
Some senders grounded via the tanks sheet metal, provided the tank itslef has a good frame ground, while other had a seperate lil grounding terminal wired to frame ground (like a plastic tank would require). Regardless which, the gauge cant deflect the needle unless the sender is good and it has a good ground.
The sender is merely a variable resistor, depending on if the float is at the bottom (empty) or at the top (full). The sender may vary from like near zero ohms at full to 30 to even 200 ohms or so at bottom empty and it must match the gauge it was designed for.
On the old ones, if the sender were removed and the float raised n lowered, the gauge ought to swing from empty to full if a ground return path is provided and all is wired correct n working.
Generally speaking, if you take the gauges output terminal (one to sender NOT one to power) and dead frame ground it, the gauge ought to swing to FULL but if its open and unattached it ought to show empty, as no current can pass through it. Therefore, if its always reading FULL theres a short in the wire down to the sender or the senders bad BUT if it always reads empty and the gauge never deflects, theres either an OPEN in the wire to the sender, or the senders bad, or the sender isnt getting a good ground (via tank or seperate wire), or else theres no voltage present on thre gauges input.
If the gauge flutuates wildly, Im would suspect either an open or shorted or intermnittent wire to the sender or else the sender is bad ASSUMING the gauge is okay. If the gauge swings from FULL when wire to sender is grounded but stays on empty with nothing attached to the sender terminal, I would think its okay.
Like I said, thats for the older tractors, so trust the guys who have knowekedge of the newer tractors more than myself.
Ol John T Another Hoosier down South of ya here in Bloomington
Indydirtfarmer
04-15-2005 17:05:48
 Re: 2440 fuel guage???? in reply to John T, 04-15-2005 08:49:02
Actually, I'm south of you... Down almost as far south as you can go in Indiana. In fact, we LIVE in Kentucky. (Louisville) The farm is near Hanover Indiana. (Near Madison)
Looks like my sending unit is bad....
John T
04-15-2005 20:27:38
 Re: 2440 fuel guage???? in reply to Indydirtfarmer, 04-15-2005 17:05:48
I lived in Hanover yearsssss sss ago and also at Madison at Clifty Falls State Park where my Grandfather was Superintendent. Thats sure beautiful country along the banks of the Ohio. My son just moved from Clarksville across the river from Louisville.
John T
txgrn
04-15-2005 17:33:28
Glad you came to that conclusion John!
John T
04-15-2005 20:29:51
 Re: 2440 fuel guage???? in reply to txgrn, 04-15-2005 17:33:28
Yeppers, it looks like he got her figured out, Congrats to the Indy man.
John T
WTW
04-15-2005 08:00:13
Indy, Pretty simple to test. Your problem is most likely the sender in fuel tank. If sender wears and develops a open spot in sender circuit it will cause your gauge to do wacky things. To test gauge and circuit to sender simply disconnect the sender wire at sender and ground it to a good clean ground point on the side of the fuel tank (if metal) or ground wire to frame (if plastic) tank. With sender wire grounded turn key switch on and watch fuel gauge to go to one extreme either clear full or clear empty (not sure which way it will go). now disconnect sender wire from ground and leave it hang not allowing it to touch anything, with key switch on the gauge should be at its opposite extreme from where it was when it was grounded. If it will change from one extreme to the other grounding sender wire and leaving it open there is nothing wrong with you gauge or wiring, replace sender. If it wont repeat test at back of gauge at sender wire connection to determine if problem is sender wire / circuit or gauge. Only two wires at gauge one is sender wire and the other is 12 volt supply from key switch which also can tested at gauge terminals. Good Luck, DW
txgrn
04-15-2005 06:46:24
Sounds like your sending unit has a worn out 3rd contact..... the one that moves up and down.
I have taken several of these things apart that operate erratically and either the wire is broken ( where they would read good to a point then go nuts) or they just go nuts when they are of a mind which is the brass end of the wiper arm that is supposed to be touching the wire just does it when ready cause the round teat is worn half off and the hinge is letting it flop.
Mark
farmweld
04-15-2005 05:06:52
i would just rip it out, and carry a wire with you to check fuel level. much easier adn cheaper
3010 Ken
04-15-2005 04:31:46
Hey Mr.John; Dad has a 2640 and had trouble w/his sending unit.That was a few years back but it seems like we took it out of the tank and connected an ohm meter to it and manually worked the float up and down through it's range of movement.You should see the resistance change as you move the float arm.With the ohm meter you can check the wire running from the guage tothe sending unit for continuity.Pay close attention to the connections for tightness/cleanliness.By the way,I'm originally from Evansville,In.I have been here in the deeeeep south a long time though. Good luck keeping track of those fuel levels! Kenny
