JD 2010 Gas No Spark?
Deerly Parted
04-14-2005 18:12:51
I can't get spark to a friends 2010. I've replaced the coil, condenser and points and still no spark. The plug wires look good but still no fire. The darn thing hasn't run in several years but has been shedded. What do I check now? Is their a safety switch to the shifter that may kill the spark but still let the engine crank over? Thanks in advance.
jdemaris
04-15-2005 06:11:05
 Re: JD 2010 Gas No Spark? in reply to Deerly Parted, 04-14-2005 18:12:51
Should be easy to figure out, either you have power to the coil, or you do not. The original 2010 systems used an ignition resistor built into the key-switch. Later on, Deere sold change-over kits to use a "stand-alone" resistor. 2010 also used the key-switch for resistor bypass at cranking. If your 2010 has the Delco starter, and not the Prestolite, you can use the "R" terminal for the resistor bypass instead.
old
04-14-2005 20:01:23
run a hot wire from the battery to the coil and see if you have spark then if you do trace the wireing back and you should find the proplem. If you still don't have spark check to make sure the points aren't gronded out.
Bob
04-14-2005 18:44:31
Is there battery voltage to the (+) terminal on the coil?
If not, check the ignition switch and ignition resistor, of which (I believe) there were a couple of variations, until you find where the voltage is getting lost.
Any safety switches would affect cranking, and NOT ignition.
