140 Lawn Tractor
Brian Ramsbey
04-14-2005 11:22:18
I have a 1964 140 Lawn tractor with electric PTO, Hydrostatic and a Kohler engine. The Serial number is less than 10000. The problem I am having is the PTO Electric Clutch shorted out burning up all the ignition wires to the point I am having to completely rewire from scratch. The problem I am having in the 'service' manual I have has a beautiful schmatic for 10000 and up tractors but has nothing but a block diagram for below 10000 serial numbers. I was able to get everything hooked back up on my own except the engine ignition. When I crank the engine the points turn cherry red and burn up in a very short time. Does anyone know how or have a schmatic that would work for this tractor. Its time to mow again and I would really like to get this one running again.
Bob
04-14-2005 14:06:52
 Re: 140 Lawn Tractor in reply to Brian Ramsbey, 04-14-2005 11:22:18
A 140 of that s.n. is MAGNETO IGNITION, and all the ignition switch does is short the mag to ground when the key is turned to "off", to stop the engine.
There should NEVER be 12 Volts from the battery to the ignition system.
Either you have it wired up wrong, or you have replaced the ignition switch with the wrong part # switch. The switches for battery and magneto ignition LOOK the same (but are totally different inside), so that is an easy mistake to make.
Besides cooking the points, you may have fried the magneto ignition coil, which is located beneath the engine flywheel, and requires the engine to be removed for access.
The magnetic clutch circuit is protected by a circuit breaker, which should have prevented the damage in the first place, unless someone has removed that from the circuit.
Other possible problems, if there has been wiring harness damage, are a burned out solid-state voltage regulator, or a burned out alternator stator, located beneath the flywheel, with the ignition coil. However, with damage to either, it will start and run, but not charge the battery.
The correct Deere part # for the ignition switch is AM102543, @ $17.25.
Brian Ramsbey
04-14-2005 14:23:12
 Re: 140 Lawn Tractor in reply to Bob, 04-14-2005 14:06:52
Ok, I am getting that from others also now, Now I am at an impass. I still need to know HOW it is wired to be able to fix it, the ignition switch was toast and the connector. I will need to put something in which I don't have a problem with if I only know exactly how the wiring should go. I know now I was told wrong in the begining in that this is a 1968 tractor with a 12 HP K301 Kohler and yes it is the Magneto ignition. It has a potted three prong voltage regular and some wire coming off the engine which are still in tact. Everything else had to be replaced due to the melt down. And yes there was no circuit breaker as people describe, I see where one was but its been bypassed years ago(not by me). This tractor was a sad case when I got it and I fixed up and the mechanicals but I never redid the wiring. Everything was good until the Electric Clutch shorted out from wear.
Brian R.
Bob
04-14-2005 15:52:29
 Re: 140 Lawn Tractor in reply to Brian Ramsbey, 04-14-2005 14:23:12
Brian, I've worked with many of these, and I'll see what I get out of the shop manual, as it's been awhile.
To get it running, NO connection from the points to the igntion switch is needed, but of course, then it will not shut off with the key. (But at least you'll know it's OK that far, and then you can proceed with the rest of the wiring.)
The small wire from the ignition coil, the condensor, and the insulated screw on the breaker points are all connected in common.
At that point, the engine should have spark, and start, otherwise you'll have to replace the points, and coil, as needed, until you get spark.
From that common point, a lead goes to the center terminal on the 3-wire connector beside the engine. From there, the wire goes to the ignition switch. I can't remember offhand how that terminal is labled, but with the switch "OFF", it will be the only terminal that will show conductivity to the metal housing of the switch, when checked with an ohmmeter, or a battery powered test light.
kf
04-14-2005 12:48:03
Check out the website below for JD 140 Lawn tractor info.
Link
