Dan, the main front pump is "charged" with oil by a gear pump back in the transmission. There is a check valve or two involved with keeping the oil line filled from the transmission pump, to the oil cooler, to the main front pump. There must be oil available up at the front pump for it to begin pumping. (The oil is forced up front, the front pump does not "suck" it from the supply at the rear of the tractor.) So any problems with the sump screen for the transmission pump, the pump itself, or check valves can cause a delay in getting oil to the main pump. Often, the wet brakes fail and shed material, plugging the sump screen, so check that first! Of course, if you are getting the needed oil to the front pump, there are a number of reasons, including the stroke control valve on the main pump that will cause it to hesitate to begin pumping. You need to check for the presence of charge oil supply to the top of the main front pump, before you even consider replacing this EXPENSIVE unit! A factory Deere manual, with color-coded oil flow diagrams, and thorough troubleshooting procedures is INVALUABLE to have before throwing the big money at a replacement pump!
