Generator or Alternator?
DeereDave
04-14-2005 10:25:43
I'm putting a starter on my '45 A and when I mentioned to a friend I had a good used generator I could use, he said he thought I should use an alternator instead, but wasn't real sure. Since I'm "green" at this, I'm asking you good fellas which one and why. Hey, thanks a bunch. Without this website I'd be making no progreea at all.
Mike M
04-14-2005 11:26:07
 Re: Generator or Alternator? in reply to DeereDave, 04-14-2005 10:25:43
It depends on what you are going to do with the tractor. If it is a hand start tractor with just a started added and it is a work tractor I'd go with 12volt and use an alternator.Alternators take less wireing to hook up,last longer,and are less costly to buy and fix. If it is being restored and was a factory electric start I'd go with the original type gen. and 6 volt.
DeereDave
04-15-2005 04:45:20
 Re: Generator or Alternator? in reply to Mike M, 04-14-2005 11:26:07
Mike M,
Thanks for the reply. It was a hand start and I'm adding a starter and do want to go 12 volt. So I'll go with the alternator.
