52 A Clutch
Dave from Texas
04-14-2005 07:52:06
Does the pulley gear move in and out with the operating sleeve when the clutch is operated or is mine just stuck together? I see in the book that there is a Sleeve snap ring. Does that snap ring hold the two pieces together?
Lee B
04-15-2005 06:15:34
 Re: 52 A Clutch in reply to Dave from Texas, 04-14-2005 07:52:06
What Mike said, but they do move together just a little bit, say up to 1/2 inch before I'd tear it down to fix that particular problem if that was the only problem. Crankshaft end play would be involved here too so don't forget to account for that 'play' as well.
Mike M
04-14-2005 11:31:07
That pulley gear is a tight press fit onto the center hub of the pulley. I think the snap ring you are asking about may be what that gear bottoms against when you press it on. The operating sleeve should slide freely up and down but not rotate.
